Fedora 28 - Broadcom 4322 Wifi Issue after upgrading to kernel 4.17
    Jul 2018
    indore, India
    3
    Linux Firefox 61.0
    Thumbs down Fedora 28 - Broadcom 4322 Wifi Issue after upgrading to kernel 4.17
    I recently upgraded Fedora 28 on my Dell Vostro 1520 laptop to kernel 4.17 , and my wireless connections stopped working. However, it works fine under kernel 4.16. It has a Broadcom 4322 card. Kindly help me debug and fix the issue.
    964
    Re: Fedora 28 - Broadcom 4322 Wifi Issue after upgrading to kernel 4.17
    Jul 2018
    indore, India
    3
    Linux Firefox 61.0
    Thanks .. I'll have a look into it .. In the meantime , can anyone help me trace what component/firmware is failing to load
    6,699
    Windows NT 10.0 Chrome 67.0.3396.99
    Quote Originally Posted by LuckyDudeThakur
    lack of akmods would cause the failure to re-install the driver when you upgrade the kernel. best start again with the driver installation and make sure akmods is up and running:
    sudo dnf install -y https://download1.rpmfusion.org/nonfree/fedora/rpmfusion-nonfree-release-28.noarch.rpm https://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-28.noarch.rpm
    sudo dnf install -y broadcom-wl kernel-devel
    sudo akmods --force --kernel `uname -r` --akmod wl
    sudo modprobe -a wl
    Jul 2018
    indore, India
    3
    lsmod | grep wl reports the driver is loaded:
    #lsmod|grep wl
    wl 6463488 0
    cfg80211 770048 1 wl
    After running akmods --force I'm getting no errors, the driver supposedly loads fine with modprobe wl, too.
    #akmods --force
    Checking kmods exist for 4.17.4-200.fc28.x86_64 [ OK ]
    #modprobe wl
    After loading wl with modprobe I'm getting this error with dmesg, which I believe is linked to my problem:
    [ 17.101676] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [ 17.102826] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [ 17.138079] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [ 17.138084] cfg80211: failed to load regulatory.db
    Another user is facing similar issue with his Fedora 28 installation but with different Broadcom adapter:
    https://unix.stackexchange.com/quest...fi-doesnt-work
    Kindly help.
  1. unable to get broadcom 4322 working - running latest fedora 19 - 3.10 kernel
    By muneeb in forum Installation, Upgrades and Live Media
    Last Post: 15th September 2013, 02:02 PM
  2. Help getting Broadcom 4322 WiFi to work
    By madvoid in forum Hardware & Laptops
    Last Post: 23rd January 2013, 06:57 PM
  3. F16 x64 broadcom 4314 wifi issue
    By mbalaci in forum Hardware & Laptops
    Last Post: 11th November 2011, 07:30 PM
  4. Broadcom 4322 firmware missing on F15
    By Varik in forum Using Fedora
    Last Post: 19th August 2011, 02:36 PM
  5. Fedora 15 dont recongnize Broadcom BCM 4322 wireless card
    By jorgebadad in forum Using Fedora
    Last Post: 17th August 2011, 06:05 PM
