    Jul 2018
    Italy
    Linux (Fedora) Firefox 57.0
    Monitor Mode
    Hi everyone! I'm a new user of Fedora and so I'm a very beginner of Linux world...
    I want to set my internet card in monitor mode, I tried with ifconfig but I receved an error: SIOCSIFFLAGS: Operation not permitted
    Someone can help me?
    Apr 2009
    central NY, USA
    1,092
    Linux Firefox 52.0
    Re: Monitor Mode
    Do you mean you wish to sniff packets? If so, the repos have wireshark available. Also, I believe tcpdump (command line tool) is built in.
    Or am I misunderstanding what you wish to do?
    Change - the only constant.
    Jul 2010
    western PA
    110
    Re: Monitor Mode
    First off, you cannot wire sniff unless the card is in promiscuous mode, then there is the issue of hubs vs switches. in a switched environment you won't see ethernet segment traffic that is not either destined for the target host or is a broadcast. Wireshark is hands down the best freebie tool available for seeing and analyzing packets. tcpdump will give you raw data but then you need to have some tools to analyze it. Finally, you generally cannot sniff unless you are the root user. a WAG is that your IOCTL error is due to not accessing the card as root.
  1. Bug in dual monitor mode
    By inszyby in forum Hardware & Laptops
    Last Post: 1st July 2012, 07:13 PM
  2. mdadm and monitor mode
    By shadowwyvern in forum Servers & Networking
    Last Post: 9th August 2006, 10:51 AM
  3. ipw2200 and monitor mode
    By sciguy125 in forum Hardware & Laptops
    Last Post: 28th July 2006, 04:47 AM
  4. How do I come out of monitor mode?
    By djbeenie in forum Servers & Networking
    Last Post: 25th October 2005, 10:24 PM
  5. ipw2200 Monitor Mode
    By Singee15 in forum Servers & Networking
    Last Post: 24th July 2005, 06:17 PM
