Need Help While Using tcpdump Command
    May 2018
    Canada
    23
    Linux (Fedora) Firefox 60.0
    I am using tcpdump output and I see this entry:
    4:56:27.742567 IP 174.143.140.137.80 > 192.168.2.21.45704: Flags [S.], seq 3555324792, ack 2292208597, win 5792, options [mss 1452,sackOK,TS val 593134436 ecr 91197600,nop,wscale 6], length 0
    Can anyone tell me what it means?
    Thanks
    944
    Re: Need Help While Using tcpdump Command
    4:56:27.742567 I think timestamp since boot
    IP 174.143.140.137 is sending a packet on port 80
    to IP: 192.168.2.21 on remote port 45704 , which tells me that the 192.168.2.21 requested an HTTP connection from 174.143.140.137 (and the port 45704) is the outgoing connection port in your local machine, which has ip: 192.168.2.21
    length 0 at the end means it probably didn't receive anything.
    try doing: tcpdump -s 192
    May 2018
    Canada
    23
    Thanks so much. That helps a lot.
  1. Tcpdump
    By mamehmood in forum Servers & Networking
    Last Post: 19th February 2009, 01:56 AM
  2. Tcpdump...??
    By sheridon in forum Security and Privacy
    Last Post: 18th June 2006, 05:58 PM
