[SOLVED] FC28: Hardware Error and reboot
Results 1 to 7 of 7
    Feb 2007
    88
    I have a lot of errors like these
    Quote Originally Posted by journalctl -p 3 -r
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: PROCESSOR 2:600f20 TIME 1528974666 SOCKET 0 APIC 1 microcode 6000852
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: TSC 0 MISC c008000200000000
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: CPU 1: Machine Check: 0 Bank 2: d800000000050153
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: PROCESSOR 2:600f20 TIME 1528974666 SOCKET 0 APIC 0 microcode 6000852
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: TSC 0 MISC c012000001000000
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 4: ba00001000020c0f
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: TSC 0 ADDR 107c0 MISC c008000100000000
    Jun 14 14:11:08 fc-pc kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 2: be0040f00010010a
    -- Reboot --
    Jun 14 13:13:32 fc-pc kernel: mce: [Hardware Error]: PROCESSOR 2:600f20 TIME 1528971209 SOCKET 0 APIC 0 microcode 6000852
    Jun 14 13:13:32 fc-pc kernel: mce: [Hardware Error]: TSC 0 ADDR 1bbadb658 MISC c012000001000000
    Jun 14 13:13:32 fc-pc kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 4: fe00000000070f0f
    Jun 14 13:13:32 fc-pc kernel: mce: [Hardware Error]: TSC 0 ADDR 7
    Jun 14 13:13:32 fc-pc kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 1: b600000000100153
    -- Reboot --
    Jun 14 11:58:11 fc-pc kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [code:7601]
    Jun 14 11:58:03 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 23s! [chrome:3637]
    Jun 14 11:57:43 fc-pc kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [code:7601]
    Jun 14 11:57:35 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 23s! [chrome:3637]
    Jun 14 11:57:15 fc-pc kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [code:7601]
    Jun 14 11:57:07 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 23s! [chrome:3637]
    Jun 14 11:56:47 fc-pc kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [code:7601]
    Jun 14 11:56:39 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 23s! [chrome:3637]
    Jun 14 11:56:11 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 22s! [chrome:3637]
    Jun 14 11:55:44 fc-pc kernel:          (t=60000 jiffies g=440898 c=440897 q=69015)
    Jun 14 11:55:44 fc-pc kernel:         7-....: (39995 ticks this GP) idle=812/1/4611686018427387906 softirq=306709/306709 fqs=9737
    Jun 14 11:55:44 fc-pc kernel: INFO: rcu_sched self-detected stall on CPU
    Jun 14 11:55:27 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 21s! [chrome:3637]
    Jun 14 11:55:04 fc-pc kernel: rcu_sched kthread starved for 60002 jiffies! g440897 c440896 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x402 ->cpu=0
    Jun 14 11:55:04 fc-pc kernel:         (detected by 7, t=60002 jiffies, g=440897, c=440896, q=45274)
    Jun 14 11:55:04 fc-pc kernel:         1-...!: (1 GPs behind) idle=2b0/0/0 softirq=309315/309316 fqs=0
    Jun 14 11:55:04 fc-pc kernel:         0-...!: (0 ticks this GP) idle=3e0/0/0 softirq=571180/571180 fqs=0
    Jun 14 11:55:04 fc-pc kernel: INFO: rcu_sched detected stalls on CPUs/tasks:
    Jun 14 11:54:35 fc-pc kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 22s! [chrome:3637]
    -- Reboot --
    Jun 14 10:33:27 fc-pc kernel: [Hardware Error]: cache level: L2, tx: INSN, mem-tx: IRD
    Jun 14 10:33:27 fc-pc kernel: [Hardware Error]: MC2 Error: Fill parity error on insn fills.
    Jun 14 10:33:27 fc-pc kernel: [Hardware Error]: CPU:0 (15:2:0) MC2_STATUS[-|CE|MiscV|-|-|-|-]: 0x9800000000050152
    Jun 14 10:33:27 fc-pc kernel: [Hardware Error]: Corrected error, no action required.
    Quote Originally Posted by inxi -Fxmz
    System:    Host: fc-pc Kernel: 4.16.14-300.fc28.x86_64 x86_64 bits: 64 gcc: 8.1.1 Console: tty 0
               Distro: Fedora release 28 (Twenty Eight)
    Machine:   Device: desktop Mobo: ASUSTeK model: M5A78L-M LE v: Rev X.0x serial: <filter>
               BIOS: American Megatrends v: 1601 date: 11/27/2013
    CPU:       8 core AMD FX-8300 Eight-Core (-MCP-) arch: Bulldozer rev.0 cache: 16384 KB
               flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 53037
               clock speeds: max: 3300 MHz 1: 1404 MHz 2: 1394 MHz 3: 1403 MHz 4: 1400 MHz 5: 2716 MHz 6: 3420 MHz
               7: 1398 MHz 8: 1404 MHz
    Memory:    Array-1 capacity: 8 GB devices: 2 EC: None
               Device-1: DIMM0 size: 8 GB speed: 667 MT/s type: Other part: N/A
               Device-2: DIMM1 size: No Module Installed type: N/A
    Graphics:  Card: NVIDIA GK208B [GeForce GT 710] bus-ID: 01:00.0
               Display Server: X.org 1.19.6 drivers: vesa,nouveau (unloaded: modesetting,fbdev)
               Resolution: 1920x1080@60.00hz, 1920x1080@60.00hz
               OpenGL: renderer: NV106 version: 4.3 Mesa 18.0.2 Direct Render: Yes
    Audio:     Card-1 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
               Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
               driver: snd_hda_intel bus-ID: 00:14.2
               Sound: Advanced Linux Sound Architecture v: k4.16.14-300.fc28.x86_64
    Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
               driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 02:00.0
               IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Drives:    HDD Total Size: 500.1GB (8.1% used)
               ID-1: /dev/sda model: WDC_WD5000AAKX size: 500.1GB temp: 38C
    Partition: ID-1: / size: 442G used: 23G (6%) fs: ext4 dev: /dev/sda3
               ID-2: /boot size: 488M used: 197M (44%) fs: ext4 dev: /dev/sda1
               ID-3: swap-1 size: 17.18GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
    RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
    Sensors:   System Temperatures: cpu: 40.0C mobo: 37.0C
               Fan Speeds (in rpm): cpu: 1956 sys-1: 3000
    Info:      Processes: 294 Uptime: 8 min Memory: 1541.0/7957.7MB Init: systemd runlevel: 5 Gcc sys: 8.1.1
               Client: Shell (sudo) inxi: 2.3.56
    Quote Originally Posted by dmesg | grep microcode
    [    0.019000] mce: [Hardware Error]: PROCESSOR 2:600f20 TIME 1528974666 SOCKET 0 APIC 0 microcode 6000852
    [    0.021156] mce: [Hardware Error]: PROCESSOR 2:600f20 TIME 1528974666 SOCKET 0 APIC 1 microcode 6000852
    [    1.309723] microcode: microcode updated early to new patch_level=0x06000852
    [    1.309741] microcode: CPU0: patch_level=0x06000852
    [    1.309746] microcode: CPU1: patch_level=0x06000852
    [    1.309752] microcode: CPU2: patch_level=0x06000852
    [    1.309756] microcode: CPU3: patch_level=0x06000852
    [    1.309764] microcode: CPU4: patch_level=0x06000852
    [    1.309768] microcode: CPU5: patch_level=0x06000852
    [    1.309774] microcode: CPU6: patch_level=0x06000852
    [    1.309781] microcode: CPU7: patch_level=0x06000852
    [    1.309804] microcode: Microcode Update Driver: v2.2.
    Quote Originally Posted by dnf list microcode*
    Last metadata expiration check: 2:13:03 ago on Thu 14 Jun 2018 12:08:41 PM EEST.
    Installed Packages
    microcode_ctl.x86_64        2:2.1-23.fc28        @updates
    How to fix this issue?
    6,271
    Re: FC28: Hardware Error and reboot
    try disabling C-states in the motherboard's firmware settings
    Feb 2007
    88
    I've disabled C-state, but a new error is appeared
    -- Reboot --
    Jun 15 09:51:20 fc-pc kernel: nouveau 0000:01:00.0: fifo: SCHED_ERROR 0a [CTXSW_TIMEOUT]
    Jun 15 09:51:15 fc-pc kernel: nouveau 0000:01:00.0: gr: GPC0/TPC0/TEX: 80000009
    Jun 15 09:51:15 fc-pc kernel: nouveau 0000:01:00.0: gr: TRAP ch 5 [003fadd000 Xorg[2029]]
    Freezes and reboots...
    917
    Linux (Fedora) Firefox 60.0
    I recommend disabling the nouveau graphics driver, and installing the rpmfusion kmod-nvidia
    (first enable their repository: https://rpmfusion.org/Configuration )
    and then follow this guide (I guess your card would be Legacy GeForce 6/7):
    https://rpmfusion.org/Howto/NVIDIA?h...tegoryHowto%29
    Once that is done and it works and you rebooted, then modify your /etc/default/grub file to contain:
    GRUB_CMDLINE_LINUX="rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1 rhgb quiet nmi_watchdog=0 nohpet pci=biosirq rcu_nocbs=0-7"
    then type: grub2-mkconfig -o /boot/grub2/grub.cfg (that last path maybe different is you boot with EFI)
    then reboot
    Feb 2007
    88
    I used nvidia driver via akmods but I had FC28: Kernel memory exposure attempt detected from SLUB object 'nvidia_stack_cache'
    917
    Quote Originally Posted by Ex_Soft
    I would not worry about that though.
    Feb 2007
    88
    This fixed the issue
  1. reboot after resume on f28 with kernel 4.16.13-300.fc28.x86_64
    By robbnl in forum Installation, Upgrades and Live Media
    Last Post: 5th August 2018, 04:11 PM
  2. Replies: 2
    Last Post: 10th May 2018, 03:48 PM
  3. FC28 - Few questions
    By Skeleton in forum Using Fedora
    Last Post: 10th May 2018, 02:25 PM
  4. fc28 dnf update
    By oystercatcher in forum F28 Development Forum
    Last Post: 15th April 2018, 04:34 AM
  5. Replies: 0
    Last Post: 22nd June 2005, 08:57 PM
