Fedora 28...SSD and HDD problems
    Jun 2018
    Europe
    Hello! I'm totally new to both the forum and Linux. Please excuse me for bad English. So please be excused for stupid questions, but I could not find answers. I want to install Fedora 28 on a laptop with two hard drives. The first hard disk is SSD 512 GB and the second HDD 1 TB. The first problem is still with disk partitioning. I choose "custom", but then shows me the two discs united. Total size. I want to mount the root filesystems "/", "/boot" and "/swap" on the SSD. And on the HDD to mount "/home". There is no way to do so because the two drives show them as one with a total capacity of 1.5 TB. When I choose an "advance custom" I manage to do it this way, but then create two folders "/boot" of exactly the same content. Because of this, two options are exactly the same when bootloader is loaded. There is only one operating system (Fedora 28) on the computer, and there are two identical choices in the bootloader. One directory is "/boot" and the other "/home /boot". Please help how to divide the disks when there are two hard drives of different types. And why two options for the same operating system come in my bootloader, as I put Fedora on a clean laptop. Thanks in advance!
    6,697
    Re: Fedora 28...SSD and HDD problems
    have you got RAID enabled for the storage controller in the laptop's UEFI firmware because it seems like a potential cause? If so try switching to AHCI mode. with some new laptops (Signature Edition for Microsoft Windows) you may need a firmware update from the manufacturer to allow this switch of storage mode.
    Jun 2018
    Europe
    Hello! Thanks for the reply! My laptop uses AMI BIOS 2.17. There is only one option for SATA Mode and it is AHCI. No other options available. BIOS shows two separate disks, during installation when selecting "custom" also shows two separate disks but with a total volume (common space). I want to mount "/", "/bоot" and "swap" to SSD because it's faster. But Fedora mounts them somewhere in the total volume (common space) of the two discs. I can not specify a specific mount disk.
    Oct 2014
    Texas, USA
    65
    Linux (Fedora) Chrome 67.0.3396.87
    When doing the custom install you are allowed to select which drive to use for a partition. You can at that time select where the /, /boot, and swap partitions are located (on the SSD) and where /home is located (on the HDD).
    It sounds like you need to play with the LVM configuration and might need to create 2 different LVMs (one on each physical device). Since Fedora uses lvm by default, it causes all physical devices to be part of the same lvm until you tell it to do differently. Your defining the locations to be on a specific physical device creates a need for a custom lvm configuration.
  1. Replies: 4
    Last Post: 9th May 2018, 11:55 PM
  2. problems with fedora
    By proworldpeace in forum Using Fedora
    Last Post: 13th December 2016, 10:10 PM
  3. fedora 21 problems
    By gkarakou in forum Using Fedora
    Last Post: 23rd January 2015, 01:56 PM
  4. GRUB problems with Fedora 13 over-writing Fedora 10
    By greg.harvey in forum Installation, Upgrades and Live Media
    Last Post: 15th August 2010, 11:17 PM
  5. Fedora 8 to fedora 10 upgrade MDADM problems
    By kenned3 in forum Using Fedora
    Last Post: 22nd February 2009, 06:03 PM
