[SOLVED] No sound after resume, needs to reboot
Results 1 to 7 of 7
    Apr 2011
    86
    I'm using Fedora 28 KDE and my computer has 2 soundcards, an Intel Integrated Audio and a Terratec Phase 22 PCI soundcard (ICE1724). When resuming after suspend the Terratec soundcard doesn't work. I searched for a solution but all I found was mostly for Debian based distros. The "pulseaudio -k && sudo alsa force-reload" solution works for Debian based distros but it doesn't have an equivalence in Fedora or at least I don't know how to do it and I didn't find how to do it.
    Could you give me an idea about how to solve it?
    Thank you very much in advance.
    Apr 2011
    86
    Re: No sound after resume, needs to reboot
    I did a search on this forum and I found this thread:
    https://forums.fedoraforum.org/showt...suspend-resume
    But it doesn't work on F28:
    sudo rmmod snd* soundcore
    rmmod: ERROR: Module snd* is not currently loaded
    rmmod: ERROR: Module soundcore is in use by: snd
    Any idea?
    Apr 2011
    86
    Linux (Fedora) Firefox 62.0
    This issue seems to be around 10 years old it's weird there's no solution yet. Even it seems to be a patch which solves it but it has never been applied to Fedora.
    Apr 2011
    86
    This is an old thread about this issue: https://www.spinics.net/lists/alsa-devel/msg25090.html
    6,706
    Windows NT 10.0 Chrome 70.0.3538.67
    well it seems from the lack of responses that nobody here has an answer for you unfortunately. you have a very unique setup which unless someone else had the same and solved it somehow we can't really help in the user forum. have you tried ask.fedoraproject.org?
    Apr 2011
    86
    Thank you for your reply.
    I'll try with ask.fedoraproject.org
    It's weird because the ice1724 chipset is fairly common.
    Apr 2011
    86
    Linux (Fedora) Firefox 63.0
    Finally, I found a solution here:
    https://www.dell.com/community/Linux...5169011/page/2
    The script works nicely.
  1. No Sound after Resume
    By JoaoMachado in forum Alpha, Beta & Snapshots Discussions (Fedora 10 Only)
    Last Post: 4th November 2008, 12:08 AM
  2. FC8: Sound hangs after suspend/resume
    By tjrob in forum Hardware & Laptops
    Last Post: 24th December 2007, 09:25 PM
  3. Fedora 7 sound appears after resume
    By dshaw7 in forum Using Fedora
    Last Post: 6th November 2007, 12:48 AM
  4. No sound after resume with FC5 on ThinkPad 600X
    By Cabbage in forum Hardware & Laptops
    Last Post: 30th August 2006, 05:56 PM
