network drops out on FC27 - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Sep 2009
    58
    Linux (Fedora) Firefox 62.0
    Re: network drops out on FC27
    As an update, i am using kernel 4.18.5 (i think) and still getting the systemd-journal issue - there are two scenarios:
    1. I plug in the plugable USB2.0 adapter and it appears/disappears from the wireshark list, and systemd-journal is invoked.
    2. I plug in the plugable USB2.0 adapter and it appears no issue in wireshark, and when i plug in the ethernet cable, then systemd-journal is invoked. (not sure if Network-Manager has an issue as i sometimes see that in the list of top commands - appearing).
    Regards,
    Shadders.
    Sep 2009
    58
    As a further update - have been using kernel 4.18.11 and this has been working with the Plugable USB 2.0 ethernet adapter first time every time.
    Upgraded to kernel 4.18.12 and the Plugable USB 2.0 ethernet adapter is appearing/disappearing in the wireshark adapter view - seems to stabilise after a while - had one invoke of systemd-journal due to the problem.
    Whatever was done in 4.18.12, then it needs to be reversed to the code in 4.18.11
    Regards,
    Shadders.
    Sep 2009
    58
    As an update, the disappearing/appearing seems to be minimal for 4.18.12. When the PC has ben unlock, or possibly still going through the boot sequences is when it happens.
    Regards,
    Shadders.
  1. Fedora 15 Drops Network after Suspend
    By tomr55 in forum Servers & Networking
    Last Post: 5th April 2012, 10:15 AM
  2. Network Connectivity drops out randonly
    By Bartzy in forum Using Fedora
    Last Post: 22nd January 2010, 01:22 AM
  3. network connection drops, r1000+samba
    By phybere in forum Using Fedora
    Last Post: 25th January 2008, 08:08 AM
  4. Network drops every few minutes
    By wyldeone in forum Servers & Networking
    Last Post: 13th February 2005, 12:08 AM
