[SOLVED] HDMI not working, Fedora 28 PLEASE HELP !!
Results 1 to 10 of 10
    Jun 2018
    Everywhere, but nowhere
    12
    Question HDMI not working, Fedora 28 PLEASE HELP !!
    I have installed Fedora on my Sony VAIO laptop. I want to connect to a bigger display, my monitor. The laptop has an HDMI port, that's it. No VGA. I plug in my monitor and it goes into sleep mood. The laptop doesn't detect it in Display settings nor will it show on the monitor when I boot into BIOS. Any suggestions or anything I can do? (The graphics is Intel HD Graphics 4000)
    Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth. - Oscar Wilde
    Ventura, CA
    432
    Re: HDMI not working, Fedora 28 PLEASE HELP !!
    Try holding down the fn button (next to ctrl key) and then click on the proper f key (the one that has an icon on it that looks like a monitor between two vertical lines), maybe the f4 key.
    Jun 2018
    12
    I have tried that, to no avail. The button you're talking about is the F7 button for me.
    Ventura, CA
    432
    Did you try connecting to the monitor before boot (reboot)? Try going to "Display" (Applications > Settings > Display). Click on "Configure new displays when connected". Maybe click on "Identify Displays" Then click on "Apply" (all of this in the "Display" window). If it still doesn't work try rebooting.
    Also check out this bug report: https://bugzilla.redhat.com/show_bug.cgi?id=1411832 I know this is for Fedora 25, but you might glean some useful information in the comments section.
    Jun 2018
    12
    I have tried with it connect before boot up and reboot. My settings don't give me that option. I saw in the bug report people were removing "nomodeset" how do IClick image for larger version.
Name:	Screenshot from 2018-06-04 10-02-22.jpg
ID:	29635 do this?
    6,830
    press e when grub boot menu appears and use the cursor keys to move the text cursor. delete the term nomodeset and then press CTRL+X or F10 to boot. it's a temporary change at this point to see if it works. if it does you can then worry about making the change permanent afterwards by editing the grub configuration file and updating grub.
    also, check for any UEFI firmware updates (may be referred to as BIOS updates still by the VAIO support site) for your notebook.
    Jun 2018
    12
    What is the grub boot menu ?
    6,830
    Quote Originally Posted by Zboy745
    https://duckduckgo.com/?q=what+is+gr...u&t=ffab&ia=qa
    while I don't mind doing a certain amount of hand holding, please look some things up for yourself
    Jun 2018
    12
    I figured it out lol. It works!! I got rid of nomodeset in the grub menu and it works! I even get animation I didn't know I had! How do I make this permanent?
    Jun 2018
    12
    EDIT: Nevermind. I did some research myself and found how to make it permanent. Thank you so much for your help. I wouldn't have figured this out with you. Thank you so much. Attached is a vid of my whole setup. It is complete now thanks to you.
    My Setup
  1. HDMI Audio not working with NVIDIA card on Fedora 17
    By megaloman in forum Hardware & Laptops
    Last Post: 14th October 2012, 08:10 PM
    HDMI Audio Not Working
    By Kissell in forum Using Fedora
    Last Post: 20th May 2012, 12:26 PM
  3. Nvidia GTX 580 HDMI audio not working on Fedora 16 Verne
    By Resilldoux in forum Hardware & Laptops
    Last Post: 26th November 2011, 11:37 AM
  4. [SOLVED]
    HDMI sound not working after upgrade to F15
    By ej999 in forum Hardware & Laptops
    Last Post: 4th June 2011, 09:17 AM
  5. HDMI Sound working for some things, but not everything
    By keenanparm in forum Hardware & Laptops
    Last Post: 20th November 2008, 10:28 PM
