    May 2018
    kurukshetra
    Wifi is not working in HP bs576tx laptop
    I am using fedora version 14.16 above in hp laptop model bs576tx and unable to use wifi ...
    may u tell me how to get rid of this problem
    6,136
    Re: Wifi is not working in HP bs576tx laptop
    fedora 14.16 doesn't exist and we need some more information to be able to help.
    please run the following commands in terminal and past the output here (preferably in code boxes but if you don't know how to do that we can reformat the post for you) which will help identify the actual version of fedora you are using and what wireless adaptor is installed.
    lspci
    lsusb
    uname -mrs
    thread moved to the appropriate forum section.
    May 2018
    kurukshetra
    Linux (Fedora) Firefox 57.0
    Output:-
    lspci
    [gaurav@localhost Desktop]$ lspci
    00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
    00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
    00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
    00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
    00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
    00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
    00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
    00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
    00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
    00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
    00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
    00:1f.0 ISA bridge: Intel Corporation Device 9d4e (rev 21)
    00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
    00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
    00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
    01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7 M520] (rev 83)
    02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
    03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device d723
    lsusb
    [gaurav@localhost Desktop]$ lsusb
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 003: ID 04f2:b5d5 Chicony Electronics Co., Ltd
    Bus 001 Device 002: ID 0bda:b009 Realtek Semiconductor Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    uname -mrs
    [gaurav@localhost Desktop]$ uname -mrs
    Linux 4.13.9-300.fc27.x86_64 x86_64
    Ventura, CA
    420
    Does your wifi work under Windows or other Linux distribution? I don't see any built in wifi device listed under lspci -- and lsusb shows that you have no usb wifi dongle.
  1. WiFi is not working @10m from WiFi-router
    By Cedermaker97 in forum Hardware & Laptops
    Last Post: 17th January 2016, 04:27 PM
    Wifi randomly stops working, then starts working.
    By solidtoaster in forum Hardware & Laptops
    Last Post: 19th January 2012, 04:12 PM
  3. laptop wifi - almost there
    By blue dragon in forum Hardware & Laptops
    Last Post: 5th June 2008, 01:54 PM
  4. Replies: 1
    Last Post: 26th June 2005, 08:27 PM
