    Apr 2018
    California
    32
    NFS Weirdness (F27)
    For some reason, my nfs-server.service is failing after a reboot. The related NFS services show this:
    nfs-idmapd.service loaded active running NFSv4 ID-name mapping serv
    nfs-mountd.service loaded active running NFS Mount Daemon
    nfs-server.service loaded failed failed NFS server and services
    Now, if I manually start the nfs-server.service, I get this:
    nfs-server.service loaded active exited
    At this point my networked NFS mounts work, but something is still not right. Doing a simple 'showmount -e' takes about 2 minutes to complete, but it eventually show the proper information:
    [********:~]$ showmount -e
    Export list for DSS-Fedora27:
    /run/media/********/WD-Backups 192.168.0.0/24
    /etc/exports has only the one entry:
    /backups 192.168.0.0/24(ro,sync,no_root_squash)
    I've used NFS plenty of times in the past; not sure what the problem is. Here's the log from my last reboot:
    May 8 22:10:06 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-idmapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 8 22:10:24 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-mountd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 8 22:10:24 DSS-Fedora27 systemd[1]: nfs-server.service: Control process exited, code=exited status=1
    May 8 22:10:24 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    May 8 22:10:24 DSS-Fedora27 systemd[1]: nfs-server.service: Unit entered failed state.
    May 8 22:10:24 DSS-Fedora27 systemd[1]: nfs-server.service: Failed with result 'exit-code'.
    Apr 2014
    Brooklyn
    58
    Re: NFS Weirdness (F27)
    Can you post what you have in /etc/export.
    After you reboot and wait 2 minutes are you able to start nfs-server??
    Can you open two terminals run
    tail -f /var/log/messages
    in one terminal and in the other terminal
    systemctl start nfs-server
    and post the output from messages log here.
    Apr 2018
    California
    32
    Here's my /etc/exports file:
    I'll get the rest tomorrow morning when I can reboot.
    Apr 2018
    California
    32
    As requested:
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Starting Preprocess NFS configuration...
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Started Preprocess NFS configuration.
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-config comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-config comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Starting NFSv4 ID-name mapping service...
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Starting NFS Mount Daemon...
    May 11 12:46:02 DSS-Fedora27 rpc.mountd[7077]: Version 2.2.1 starting
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-idmapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-mountd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Started NFSv4 ID-name mapping service.
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Started NFS Mount Daemon.
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Starting NFS server and services...
    May 11 12:46:02 DSS-Fedora27 kernel: NFSD: starting 90-second grace period (net f0000099)
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Stopping GSSAPI Proxy Daemon...
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Stopped GSSAPI Proxy Daemon.
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=gssproxy comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Starting GSSAPI Proxy Daemon...
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Started GSSAPI Proxy Daemon.
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=gssproxy comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 systemd[1]: Started NFS server and services.
    May 11 12:46:02 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nfs-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:02 DSS-Fedora27 audit[7069]: USER_END pid=7069 uid=0 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_keyinit,pam_li mits,pam_systemd,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
    May 11 12:46:02 DSS-Fedora27 audit[7069]: CRED_DISP pid=7069 uid=0 auid=1000 ses=3 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
    May 11 12:46:15 DSS-Fedora27 NetworkManager[1243]: <info> [1526067975.7581] manager: NetworkManager state is now CONNECTED_GLOBAL
    May 11 12:46:15 DSS-Fedora27 dbus-daemon[1011]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1243 comm="/usr/sbin/NetworkManager --no-daemon " label="system_u:system_r:NetworkManager_t:s0")
    May 11 12:46:15 DSS-Fedora27 journal[5809]: g_hash_table_lookup: assertion 'hash_table != NULL' failed
    May 11 12:46:15 DSS-Fedora27 journal[5809]: g_variant_new_string: assertion 'string != NULL' failed
    May 11 12:46:15 DSS-Fedora27 org.freedesktop.problems[1011]: abrt-dbus: Bad problem directory name '[Invalid UTF-8]', should start with: '/var/spool/abrt'
    May 11 12:46:15 DSS-Fedora27 /usr/libexec/gdm-x-session[5363]: abrt-applet: Can't chown '(null)': GDBus.Error:org.freedesktop.problems.InvalidProble mDir: '[Invalid UTF-8]' is not a valid problem directory
    May 11 12:46:15 DSS-Fedora27 /usr/libexec/gdm-x-session[5363]: abrt-applet: Can't create lock file '.lock': Bad file descriptor
    May 11 12:46:15 DSS-Fedora27 systemd[1]: Starting Network Manager Script Dispatcher Service...
    May 11 12:46:15 DSS-Fedora27 dbus-daemon[1011]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
    May 11 12:46:15 DSS-Fedora27 systemd[1]: Started Network Manager Script Dispatcher Service.
    May 11 12:46:15 DSS-Fedora27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    May 11 12:46:15 DSS-Fedora27 nm-dispatcher[7113]: req:1 'connectivity-change': new request (5 scripts)
    May 11 12:46:15 DSS-Fedora27 nm-dispatcher[7113]: req:1 'connectivity-change': start running ordered scripts...
    May 11 12:46:25 DSS-Fedora27 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    It's still failing on reboot.
  1. DNF Weirdness
    By SomeDamFool in forum Using Fedora
    Last Post: 16th September 2016, 10:38 PM
  2. Yum Weirdness
    By ArthurDent123 in forum Using Fedora
    Last Post: 7th March 2008, 12:51 PM
  3. DVD weirdness in FC6
    By flosofl in forum Hardware & Laptops
    Last Post: 26th October 2006, 05:02 AM
  4. *****X weirdness
    By slagazor in forum Using Fedora
    Last Post: 14th April 2005, 12:41 AM
