    Mar 2011
    76
    ETH0 does not connect automatically when plugged in, needs restart [Fedora28]]
    This started in fedora 27. If I am using wireless, and plugging in LAN port, I can see the light blinking but the LAN is not activated in the system.
    systemctl restart NetworkManager does not solve the problem. again wifi is connected. Only if I restart keeping the LAN plugged in, it connects.
    Recently upgraded to f28 but the problem persists.
    Any tips to resolve this problem ?
    Thanks in advance.
    Cheers,
    Dhiraj
    Apr 2014
    Brooklyn
    58
    Re: ETH0 does not connect automatically when plugged in, needs restart [Fedora28]]
    Open up a terminal and switch to root.
    nmtui
    1) click on Edit a connection
    2) select your ethernet port and click edit.
    3) maybe sure there is a X next to Automatically connect, then click OK, back and quit.
    you can also bring it up with a command, but you will have to run that command each time you plug in your ethernet cable, if you ethernet is called eth0 use
    ip link set eth0 up
    Mar 2011
    76
    Quote Originally Posted by wolfred
    nmtui
    ip link set eth0 up
    X is already next to Automatically connect.
    I checked it is eno1 in my laptop.
    It executes ip link set eno1 up but can't connect. Even if I add a new ethernet network, it does not bring it up.
    Thanks for the help anyway,
    Dhiraj
    May 2018
    Norway
    Could it be related to this bug: https://bugzilla.redhat.com/show_bug.cgi?id=1038156
  1. make process automatically restart when it stops
    By Fedora8 in forum Using Fedora
    Last Post: 8th December 2016, 11:10 AM
  2. Automatically detect when cable is plugged in?
    By jdinkel in forum Servers & Networking
    Last Post: 4th May 2006, 04:34 PM
  3. Replies: 0
    Last Post: 1st February 2006, 10:29 AM
  4. ifconfig eth0:0 <IP> is forgotten on restart
    By bonsaidouglas in forum Servers & Networking
    Last Post: 13th January 2005, 11:16 AM
