    May 2018
    San Francisco
    Recommendations on wireless hardware for a desktop?
    So, I plugged in a TP-Link Archver T2UH that I bought a while ago for just this purpose, only to learn that its Linux support has bitrotted.
    What hardware platform should I buy for minimal-fuss 802.11AC 5Ghz wifi access for a desktop?
    I've been looking around without much luck; the closest thing I've seen so far is the TP-LINK TL-WDN4800, which is allegedly Atheros-based. Another acceptable option is to perform ethernet bridging, though AC devices are slightly thin on offer there. In general, there is a paucity of conspicuously strong products of any kind: PCI-E, USB, and bridge.
    For whatever it's worth, my WiFi platform is Ubiquiti based.
    Thanks in advance.
    6,136
    Re: Recommendations on wireless hardware for a desktop?
    Quote Originally Posted by fdrfdr
    Thanks in advance.
    while it's not ac, I happen to know the TP-Link TL-WDN3800 PCI-E card with dual antenna works fine with ath9k modules and I get a very strong and reliable signal with it.
    The TL-WDN4800 you mention also uses the ath9k modules so should work just as well.
  1. Recommendations for a desktop/USB wireless adapters
    By nw60312 in forum Hardware & Laptops
    Last Post: 4th September 2011, 04:44 PM
  2. Wireless N PCI NIC for desktop recommendations
    By meatsack in forum Hardware & Laptops
    Last Post: 2nd June 2011, 05:50 PM
  3. 3 or 4 monitor hardware recommendations ?
    By pailott in forum Hardware & Laptops
    Last Post: 26th May 2009, 10:22 AM
  4. Desktop Wireless Card Recommendations Needed
    By jamoody in forum Servers & Networking
    Last Post: 24th October 2008, 05:21 PM
  5. Gigabit ethernet hardware recommendations.
    By haplo in forum Servers & Networking
    Last Post: 8th April 2005, 01:15 PM
