[SOLVED] Kodi sound problem after upgrading to F28
Results 1 to 14 of 14
    Oct 2006
    新加坡
    1,010
    1 Post(s)
    I had a perfectly working Kodi before the upgrade. After upgrading from F27 to F28, I can still play the video smoothly but the audio becomes so choppy. The audio is OK when playing music on Rhythmbox or Spotify on Chrome or when playing movies with Totem. So far, this audio problem only happens on Kodi. Not sure how to troubleshoot this. Any help would be appreciated.
    Leave no window unbroken ♪ (^。^) 
    Apr 2018
    Romania
    4
    Re: Kodi sound problem after upgrading to F28
    I have a similar issue, I get garbled sound when playing any DTS movie.
    May 2018
    Nova Scotia, Canada
    I also have this problem after the update to F28. It appears to only affect certain files, which played fine on F27. VLC is able to play the same files without distortion. An uninstall/reinstall of Kodi (+removing config folder) did not help.
    Apr 2018
    Romania
    4
    Quote Originally Posted by modemPunk
    Yes exactly. I also tried reinstalling and vlc does play videos just fine. Also it affects all outputs, analog and digital.
    May 2018
    UK
    372
    7 Post(s)
    Same issue here. Some play fine but a few x265 encoded videos I tried all had garbled sound which wasn't the case before.
    I see the version of Kodi changed in rpmfusion between 27 and 28 from Kodi-17.6-1.fc27 to kodi-17.6-8.fc28 - Looks like the issue is with the new Kodi build.
    As an experiment I downloaded the master branch of Kodi 18 Alpha 2 from github and built from source (which took some time!) and the sound problem is fixed. There are Fedora build instructions at https://github.com/xbmc/xbmc/blob/ma.../README.fedora and https://github.com/xbmc/xbmc/blob/ma...s/README.linux . You may have to install some extra packages if the build fails (and repeat cycle until success) but the error messages should point you to what's missing.
    Yes it's an Alpha release but it at least it runs and plays the sound correctly for me. Hopefully a newer update in rpmfusion will fix the problem.
    Oct 2006
    新加坡
    1,010
    1 Post(s)
    Thanks for all the responses. I guess that "I am not alone" is a good sign that it will be fixed soon in the next build by rpmfusion. Having said that, I don't see anyone creating a bugzilla issue yet and I cannot help to do it because I don't know what kind of technical detail is required to be attached aside from the description of the problem.
    Oct 2006
    新加坡
    1,010
    1 Post(s)
    I got some time to waste, so I have installed a fresh Fedora 28 using netinstall on a VirtualBox guest VM. Turned on rpmfusion and install Kodi. No doubt the video playback won't be smooth in that kind of setup, but it is playing nevertheless. And I could reproduce the exact garbled audio playback there.
    Oct 2006
    新加坡
    1,010
    1 Post(s)
    Quote Originally Posted by hogweed
    Thanks for those links. I could rebuild as well from source with Kodi 17.6 Krypton branch in my Fedora 28 guest VM and I can confirm the audio is working correctly using the newly built binary. After changing the VM to use X11 session instead of wayland (I have proprietary nvidia driver on my main host which does not play well with wayland), the video playback on my guest VM becomes bearable. So, that should get my fix of kodi for the time being.
    May 2018
    Poland
    Are there any chances to rebuild Kodi through RPMFusion? I was forced to downgrade to F27
    Nov 2004
    70
    This issue has already been fixed. Please update to the kodi package sitting in updates-testing.
    dnf --enablerepo=rpmfusion-free-updates-testing update kodi
    The kodi package uses the system copy of ffmpeg, version 4.0. Kodi 17.x and earlier used many, legacy ffmpeg interfaces and mechanisms that simply break when using a modern version. Kodi 18 has all of this fixed and works with modern ffmpeg libraries... I will be pushing Kodi 18 to Fedora 28+ once the beta is out.
    Lulz
    Oct 2006
    新加坡
    1,010
    1 Post(s)
    I have tried the new package (Kodi 17.6.9) and I can confirm it fixes my audio playback issue. Thanks.
    May 2018
    All world
    Lightbulb Re: Kodi sound problem after upgrading to F28
    UnitedRPMs ( https://unitedrpms.github.io/#repository ), has Kodi 18 working perfectly (Some months testing and updating it)...
    May 2018
    UK
    372
    7 Post(s)
    Okay just updated from rpmfusion testing and can also confirm that the sound problem is fixed. Thanks for the quick work!
    Apr 2006
    20
    Ditto on all counts. After update from updates-testing sound was fine.
    :wq
  1. November 2nd update KDE now kodi broken
    By JoshuaA in forum Using Fedora
    Last Post: 11th November 2017, 02:06 AM
  2. Kodi won't open
    By Karl6994 in forum Installation, Upgrades and Live Media
    Last Post: 23rd February 2017, 04:47 PM
  3. XBMC/Kodi no longer fullscreen after update [Mate F21]
    By LexRidge in forum Installation, Upgrades and Live Media
    Last Post: 5th August 2015, 03:16 AM
  4. Replies: 0
    Last Post: 24th May 2015, 05:00 PM
  5. No sound after upgrading to F18
    By daytooner in forum Hardware
    Last Post: 12th June 2013, 02:21 AM
[[template footer(Guest)]]
