    Nov 2016
    Cape Canaveral
    37
    Shared Mount Point
    What are some options to have a file system (say /u02) where it is Read and Write from one system but can be mounted as Read only from other Linux systems?
    EDIT: NFS looks pretty straight forward. Is this generally still used or is there a better option?
    Thanks,
    Michael
    Feb 2009
    Florida
    600
    Re: Shared Mount Point
    Study up on permissions, add a group with r/w permission and leave all others as ro. NFS fully supports permissions across the network. The one key thing to remember is that permissions operate on the user and group numbers only ( no knowledge of associated names). This means that all users and groups on your network must have the same user #'s and group #'s on all systems.
    After you get common numbering under control it will be a piece of cake
    Laptop: Toshiba / Intel B960 2.20Ghz x2/ 4GB/ 320GB SataII/ Intel HD/ fc27.x86_64
    Tower: GigaByte (970A) / AMD FX 8320 3.5Ghz x8/ 16GB/ 9TB Sata III/ AMD 6770HD/ fc28.x86_64
    Bookshelf: Shuttle DS61 (H61)/ i3-3225 3.3Ghz x2/ 16GB/ 320GB Sata II/ Intel HD 4000/ fc27.x86_64
    May 2011
    219
    When mounting, you can specify an option for read-only: mount -o ro server:/u02 /u02
  1. Mount Point Help
    By micahel8773 in forum Servers & Networking
    Last Post: 28th November 2016, 05:07 PM
  2. CD mount point
    By Fry-kun in forum Using Fedora
    Last Post: 1st December 2006, 12:11 AM
  3. mount: mount point 0 does not exist
    By hyjal in forum Using Fedora
    Last Post: 30th November 2006, 07:00 PM
  4. non-root cannot mount user cifs mount point
    By rgladwell in forum Servers & Networking
    Last Post: 6th August 2006, 05:50 PM
  5. mount: mount point /mnt/fd0 does not exist
    By NeilO in forum Hardware & Laptops
    Last Post: 5th July 2004, 02:20 AM
