    May 2009
    357
    dnf system upgrade and cinnamon
    I upgraded from Fedora 24 to 26 using "dnf system-upgrade ..."
    This seemed to work fine but only later I found a problem.
    I was using Cinnamon for my display manager and everything seemed fine.
    BUT a couple months later, I added a new user and found that
    a) switch user did not work
    b) the new user had Cinnamon set for a DM, but got gnome
    Turns out I was running gdm, but should have been running lightdm - here was the fix - run as root (or add sudo in front of commands):
    dnf install lightdm slick-greeter
    dnf groupinstall 'Cinnamon Desktop'
    systemctl disable gdm
    systemctl enable lightdm
    reboot
    Feb 2005
    London, UK
    634
    Re: dnf system upgrade and cinnamon
    Quote Originally Posted by rholme
    reboot
    You shouldn't have to reboot, just a "systemctl stop gdm; systemctl start lightdm".
    May 2009
    357
    I am sure you are right, but just because you are running one display manager, killing it and telling it to run another
    I guess I would think reboot might just be a cleaner way to go.
    Aug 2016
    Iraq
    812
    Hi all. I faced by this problem but from other side: I was searching how to make my laptop achieve auto login, & I instructed in this forum to use "Login Window" from system setting, but there was no "Login Window" !!
    Head developer of Cinnamon was here in this forum & ask me for following:
    "when user upgrade Fedora Linux from version to version using DNF, then she/he need to perform an additional step after finishing the upgrade process. This additional (final) step is to run following command:
    sudo dnf install @cinnamon-desktop
    the above command will add new features that will be missed if you do not run it. It, also, will REMOVE all old things that should be removed so as not to conflict with new features"
    I performed "sudo dnf install @cinnamon-desktop" & then reboot. Every thing then became O.K
    Fedora 26 X64 bit Cinnamon edition on Lenovo ThinkPad e550 with Intel core i7 5500 CPU @ 2.40 GH X 2, RAM = 8 GB, HHD = 1 TB, Hybrid VGA (Intel Corporation HD Graphic 5500 + Radeon R7 M265 2GB)
    May 2009
    357
    I believe that
    AND
    Are identical commands in what they do.
    I shutdown my system during an system upgrade, now can't continue to upgrade
    By lassade in forum Installation, Upgrades and Live Media
    Last Post: 22nd October 2017, 07:42 AM
  2. window-system hang, cinnamon
    By rholme in forum Using Fedora
    Last Post: 10th July 2015, 01:20 PM
  3. F21-64 + cinnamon + pidgin = icon on system tray
    By H0wdy in forum Using Fedora
    Last Post: 16th January 2015, 05:41 AM
  4. linux upgrade causes Firefox and Cinnamon to panic
    Last Post: 19th September 2014, 07:17 PM
  5. FC19 fedup upgrade to FC20 fails (won't boot System Upgrade)
    By wernermaes in forum Installation, Upgrades and Live Media
    Last Post: 15th January 2014, 02:21 PM
