Gnome shell has got big memory leaks. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Oct 2010
    Canberra
    3,025
    Re: Gnome shell has got big memory leaks.
    An interesting bit of investigation.
    It sort of confirms my view that languages with garbage collectors are dangerous - programmers can easily come to rely on the GC and overlook cases where it needs a bit of assistance.
    This thread prompted me to do some leak tests on my VICI project. Sadly it did leak, but it was a simple fix, and now the interpreter happily shows no sign of leakage. The leak occurred because I moved some code that allocated memory from after a fork call (where it did not need to be deallocated) to prior to the fork call. The move was necessary because allocating memory after a fork call is not safe in a multi-threaded program.
    User error. Please replace user and try again
    Maryland, US
    7,448
    Jun 2014
    Italy
    107
    Quote Originally Posted by Dutchy
    Memory leaks? In Gnome-shell? And the devs are looking into it? Did hell freeze over?
    So apparently their fix is to kick off the GC after every deletion. Yeah, I am confident that they will fix the performance issues for once and for all. :')
    Tecnically if kicking the GC more often 'fixes' it, it wasn't a memory leak. They should have looked into it deeply earlier probably ...
  1. Memory usage gnome-shell
    By aghorash in forum Using Fedora
    Last Post: 16th March 2016, 03:10 AM
  2. gnome-shell memory consumption
    By mario123 in forum Using Fedora
    Last Post: 16th April 2015, 08:34 PM
  3. Memory leaks in a conky lua plugin
    By elija in forum Programming & Packaging
    Last Post: 15th May 2014, 06:18 PM
  4. F18: gnome-shell memory leak?
    By borispr in forum Using Fedora
    Last Post: 8th February 2013, 12:21 AM
  5. Detecting memory leaks
    By martind1111 in forum Programming & Packaging
    Last Post: 19th October 2005, 05:00 AM
