[SOLVED] fedora 27 does not recognize my monitor
Results 1 to 13 of 13
    Mar 2018
    france
    36
    On a quad core AMD64, with a video card ati radeon hd 4350,
    fedora 27 does not recognize my monitor, which is a "Listo", the resolution is 2K: 1980x1024.
    I have installed the server xorg for ati radeon.
    here my output :
    [root@localhost phipo]# lspci |grep -i VGA
    01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710 [Radeon HD 4350/4550]
    How to activate the amd / gpu modules in the grub?
    or another setting ?
    Regards
    Philippe
    Dec 2017
    Sosnowiec, PL
    36
    54
    Re: fedora 27 does not recognize my monitor
    Post output of command as user:
    xrandr -q
    Is current resolution native for the monitor?
    marcin82
    Mar 2018
    france
    36
    Quote Originally Posted by marcin82
    xrandr -q
    [phipo@localhost ~]$ xrandr -q
    xrandr: Failed to get size of gamma for output default
    Screen 0: minimum 640 x 480, current 1280 x 1024, maximum 1280 x 1024
    default connected primary 1280x1024+0+0 0mm x 0mm
       1280x1024      0.00*
       1024x768       0.00
       800x600        0.00
       640x480        0.00
    6,606
    What cable is the monitor connected with? DVI, HDMI, VGA, Display port?
    Mar 2018
    france
    36
    it's VGA adapter
    6,606
    Quote Originally Posted by philo
    it's VGA adapter
    is it an OEM card from Dell or HP then? Usually the retail versions of the 4350 had at least one DVI output. I have a Dell AMD Radeon HD 3450 card that only has one customised connection with an adaptor for two VGA outputs instead of the usual retail specification which is why I ask. I only use that occasionally with a 1280x1024 screen so never tried pushing it to a higher resolution.
    anyway, searching found the below, try it at your own risk. it may not actually work as intended and make things worse than they are now:
    xrandr --newmode "1920x1080"  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsyncxrandr --addmode Virtual1 1920x1080
    xrandr --output Virtual1 --mode 1920x1080
    if these values don't work, adjust them accordingly to suit your monitor's actual supported resolutions
    Mar 2018
    france
    36
    I did as you recommended, but I do not know whether to apply commands in user or root mode?
    Before I had installed the same distribution and automatically it passed in 1980x1080 is 2k.
    [phipo@localhost ~]$ xrandr --newmode "1920x1080" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsyncxrandr --addmode Virtual1 1920x1080
    xrandr: cannot find output "Virtual1"
    [phipo@localhost ~]$ xrandr --output Virtual1 --mode 1920x1080
    warning: output Virtual1 not found; ignoring
    Kinds Regards
    Philippe
    Mar 2018
    france
    36
    with dmesg command i found it :
    [drm] VGACON disable radeon kernel modesetting.
    [    1.730707] [drm:radeon_init [radeon]] *ERROR* No UMS support in radeon module!
    6,606
    try with sudo in front of the commands then, you are most likely right about the commands needing root or sudo rights.
    Mar 2018
    france
    36
    it does not work in root mode !
    [root@localhost phipo]# xrandr --newmode "1920x1080"  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsyncxrandr --addmode Virtual1 1920x1080
    [root@localhost phipo]# xrandr --output Virtual1 --mode 1920x1080
    Mar 2018
    france
    36
    with Debian 8.8 or 9.3 ihave just apply a patch to the kernel
    6,606
    please read this, the same applies to posts in threads
    https://forums.fedoraforum.org/showt...Not-Showing-Up!!!
    Mar 2018
    france
    36
    hello, I reinstall my Fedora 27 system, which automatically recognized the 2k LCD screen, everything works fine!
    post/thread solved
  1. Replies: 0
    Last Post: 29th October 2017, 06:43 PM
  2. Replies: 5
    Last Post: 11th February 2010, 07:27 PM
  3. Replies: 0
    Last Post: 22nd January 2010, 07:29 AM
  4. How to recognize new monitor?
    By zabolots in forum Using Fedora
    Last Post: 21st November 2008, 01:12 AM
  5. install will not recognize monitor
    By green lantern in forum Installation, Upgrades and Live Media
    Last Post: 8th August 2005, 05:24 PM
