ASUS GL702ZC and Fan Control
    Oct 2007
    398
    First of all I'm amazed that Fedora works this well with an odd laptop. (Ryzen 7, RX 580..)
    Everything worked well out of the box (except wifi; which started working after the first update).
    I installed the amdgpu-pro-17.50-511655 drivers -- these are the newest I could find.
    I then installed lm_sensors, but the sensors_detect found nothing.
    Afterwards issuing "sensors" shows the temperature of the various components, but the fan levels always show N/A.
    $ sudo sensors
    k10temp-pci-00c3
    Adapter: PCI adapter
    temp1:        +63.5C  (high = +70.0C)
    acpitz-virtual-0
    Adapter: Virtual device
    temp1:        +63.0C  (crit = +98.0C)
    amdgpu-pci-0c00
    fan1:             N/A
    temp1:        +58.0C  (crit =  +0.0C, hyst =  +0.0C)
    Any ideas on how to read/set the fan values? I'd like to set it manually, I don't like the idea of a hot laptop.
    Many thanks,
    -turgut
    Oct 2007
    398
    Re: ASUS GL702ZC and Fan Control
    After many different kernels.. Same problem:
    # sensors
    k10temp-pci-00c3
    temp1: +52.0C (high = +70.0C)
    acpitz-virtual-0
    temp1: +52.0C (crit = +98.0C)
    amdgpu-pci-0c00
    fan1: N/A
    temp1: +74.0C (crit = +0.0C, hyst = +0.0C)
  1. Can't control volume on Asus K55DR
    By kakai in forum Hardware & Laptops
    Last Post: 20th July 2013, 02:22 PM
  2. Replies: 8
    Last Post: 15th June 2011, 06:34 AM
  3. Replies: 2
    Last Post: 9th January 2011, 03:53 AM
  4. Replies: 1
    Last Post: 15th July 2009, 12:24 AM
  5. Asus L5830 & FC4: ACPI & FREP CONTROL
    By nama4ever in forum Hardware & Laptops
    Last Post: 20th July 2005, 10:30 AM
