Updating fedora iso with newest kernel using Livemedia-creator
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
    Feb 2018
    Usa
    28
    It said no command found.
    I was trying to follow this instruction.
    https://forums.fedoraforum.org/showt...-s-work-around
    Can you please change the thread name to "Updating fedora iso with newest kernel using Livemedia-creator"? Thank you
    Ventura, CA
    427
    Re: mock command in terminal
    It looks like Fedora has pulled its livemedia-creator wiki -- hopefully they will replace it with an updated version soon. Here is something that will get you started: https://forums.fedoraforum.org/showt...-creator-usage As is explained here, first you must install lorax livemedia-creator, mock, pykickstart. You also must create your own kickstart and flatten it. As antikythera says, you must be patient and be willing to persist despite initial failures.
    Feb 2018
    Usa
    28
    Thank you. I am going to do that today. Let's see if it's successful.
    Ventura, CA
    427
    Follow steps 1 - 4 on antithykera's thread, then skip to the second thread. He chooses fedora-live-mate_compiz.ks to flatten -- there are others you could choose (fedora-live-xfce.ks, fedora-live-lxde.ks, fedora-live-soas.ks, fedora-live-kde.ks, etc.). If you choose another spin, then make sure when you flatten the fedora kickstart, you change the names accordingly (you must choose a fedora-live kickstart to flatten, otherwise you will end up with an error message. Once you get this far, ask for help so that you can change the flattened kickstart correctly.
    Ventura, CA
    427
    If anyone is following this thread -- antithykera in particular -- do you know why the fedora livemedia-creator wiki has disappeared -- and when or if fedoraproject plans to replace it??
    Ventura, CA
    427
    Overclocked, when flattening your kickstart file, be sure to change to the proper version (-version F26 --> --version F27, etc.). Also at the end of your flatten-command you don't need "--macboot" unless you are running a mac, and make sure that everything in the command refers to your kickstart (unless you have a mate_compiz kickstart you should not have anything that is referring to mate).
    6,610
    Quote Originally Posted by donatom
    it must have been removed because it was no good any more. I don't know when it will be re-written for the current tools as I'm not involved in the working group responsible for it or the wiki
    Ventura, CA
    427
    Re: Updating fedora iso with newest kernel using Livemedia-creator
    Thanks for your reply, antithykera.
    Feb 2018
    Usa
    28
    Will I just stop at 4 steps after I follow 1 - 4 steps? antikythera just said it must have been removed.
    6,610
    Quote Originally Posted by Overclocked
    we're discussing a Fedora Project wiki, not my thread. if following my thread you need to keep going and read on or the build will fail.
    Ventura, CA
    427
    Overclocked and antikythera, the fedora livemedia-creator wiki has returned -- don't know why it was temporarily replaced by an older wiki. Overclocked, follow antikythera's thread and refer to Fedora's wiki -- between the two of them you should have plenty of good information. Here is the wiki's url again:
    https://fedoraproject.org/wiki/Livem..._use_a_Live_CD
    Feb 2018
    Usa
    28
    Alright, thank you for replying. I am doing it now. I hope it works.
    Maryland, US
    7,421
    the fedora livemedia-creator wiki has returned -- don't know why it was temporarily replaced by an older wiki. ....
    On that page click "history" shows
    Ventura, CA
    427
    Marko, thanks for that information. It is obvious that the folks at FedoraProject have been hard at work revising the livemedia-creator wiki.
    Feb 2018
    Usa
    28
    Does it really create boot.iso?
  1. livemedia-creator fails - help wanted!
    By Skeeter9807 in forum Installation, Upgrades and Live Media
    Last Post: 8th October 2017, 08:22 PM
  2. F25 onwards - Livemedia-creator usage
    By antikythera in forum Guides & Solutions (Not For Questions)
    Last Post: 4th August 2017, 10:03 AM
  3. Error Using LiveMedia-Creator
    By crokett in forum Fedora Spins & Remixes
    Last Post: 17th October 2016, 08:20 PM
  4. livemedia-creator
    By sea in forum Reviews, Rants & Things That Make You Scream
    Last Post: 5th August 2013, 06:34 PM
  5. livemedia-creator: parameters?
    By livecdOrNothing in forum Installation, Upgrades and Live Media
    Last Post: 20th April 2013, 01:54 AM
