Fedora 27 Kernel 4.15 won't boot - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Jun 2017
    Ireland
    17
    Re: Fedora 27 Kernel 4.15 won't boot
    Same issue with 2400G on ASRock Mini-ITX Motherboard - AB350 GAMING-ITX/AC. Motherboard UEFI also shows temperature as 127C so that's a hardware/UEFI issue. Anyone with non Asrock board here? 4.15 freezes 4.14 boots but freezes periodically, sometimes minutes sometimes hours.
    Feb 2018
    Holland
    3
    Latest kernel...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Apr 2018
    egypt
    Same problem here, since kernel version 4.14.16, all fedora kernels doesn't boot up, fast blinking on boot.
    Vga : nvidia MSI 1060
  4. #19
    6,703
    4.16 is supposed to have proper support for the 2200G/2400G hardware. that should be available in Fedora 28 beta
    https://fedoraproject.org/wiki/Kernel
  5. #20
    Apr 2018
    egypt
    I think I found a solution that works - at least for me - till we get 4.16 on F27 , my solution was to re-install the latest driver from nvidia.
    Credits goes to
    https://www.if-not-true-then-false.c...-nvidia-guide/
    I already had the driver installed since NOV but since kernel 4.15 it stopped working, so I just used the same tutorial - starting from step "2.7 Reboot to runlevel 3" - after downloading the new driver and once it is installed the new kernel boots normally.
    Note that this worked for me, so ensure to know what you are doing.
  6. #21
    Apr 2017
    france
    19
    Hi
    I had the same problem with my old asus x71sl, geforce 9300M, core 2duo P7350. I formatted and now I boot with the kernel 4.13.9.300. All 4.15.xx.xx kernel freeze at the boot, I have reported to bugzilla but didn't have answer. https://bugzilla.redhat.com/show_bug.cgi?id=1551005
    sorry for my bad english, thanks for your understanding....
  7. #22
    May 2011
    231
    Quote Originally Posted by Tquilha
    Is everyone with these problems using similar hardware?
    I have a AMD FX6300 with a (very old...) Nvidia 9800 GT graphics card, on a gigabyte 970 motherboard and kernel 4.15.6-300 boots normally.
    I have AMD Ryzen 4-core, Asus Prime X370, nvidia GTX1050Ti and don't see any problem with kernel 4.15.17 with proprietary driver. from rpmfusion.
    Maybe check boot grub command line options or any bios settings that may conflict?
  8. #23
    Apr 2018
    Oregon
    After upgrading to the 4.15 kernel my system locked up most of the time.....
    I was able to bypass the acpi errors (they still are logged) including the clocksource error that is controlled by acpi by adding the following to the boot grub command line:
    nohz=off clocksource=pit pci=nocrs acpi-ht pnpacpi=off elevator=deadline
    Then I had it hang up at times on the network manager script. I had to edit the:
    /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service
    file by adding RemainAfterExit=yes below:
    [Service]
    Type=dbus
    BusName=org.freedesktop.nm_dispatcher
    ExecStart=/usr/libexec/nm-dispatcher
    KillMode=process
    RemainAfterExit=yes
    Then a work around to keep a stop job hanging on shutdown...
    Edited:
    /etc/systemd/system.conf
    Changing (and un commenting):
    #DefaultTimeoutStopSec=90s
    To:
    DefaultTimeoutStopSec=15s
    It's been working much better!
  1. Fedora 23 - Not able to boot after kernel upgrade
    By gautamsathe in forum Installation, Upgrades and Live Media
    Last Post: 15th December 2016, 10:24 AM
    Fedora 20 won't boot into kernel 3.14.9
    By CuddlyPython in forum Using Fedora
    Last Post: 7th July 2014, 04:38 PM
  3. Fedora 18 won't boot latest kernel 3.9
    By jcnewton in forum Hardware & Laptops
    Last Post: 7th June 2013, 09:50 PM
  4. Replies: 8
    Last Post: 2nd November 2008, 03:11 PM
  5. Cannot boot the kernel-Fedora 7
    By petercn in forum Installation, Upgrades and Live Media
    Last Post: 8th October 2007, 05:49 AM
