Fedora 27 Kernel 4.15 won't boot
Results 1 to 15 of 23
    Feb 2018
    Germany
    8
    i just built a small HTPC with Ryzen 5 2400G and installed Fedora 27 on it today as i read it has the best support for it.
    It would boot fine with Kernel 4.13 but after an update the boot option with Kernel 4.15 will result on being stuck on boot on a line like "AMD-Vi" (i have to note the exact line and add it here later).
    Kernel 4.13 has the same messages but will continue to boot.
    Without Kernel 4.15 i cannot use the integrated graphics to its full potential :/.
    Any Ideas?
    Feb 2018
    Germany
    8
    Re: Fedora 27 Kernel 4.15 won't boot
    Oh if it helps:
    Mainboard is an AsRock AB 350 Gaming-ITX/ac with BIOS/UEFI Version 4.40.
    EDIT: Hmm ... "journalctl -b -1" "-2" etc in terminal only shows boot logs with "Linux version 4.13.9-300.fc27.x86_64" as if kernel 4.15 doesn't boot at all :/.
    Feb 2018
    Holland
    3
    I have exactly the same problem. I have a separate video card, I can boot well with kernel 4.13. I have not tried the integrated video card yet.
    Feb 2018
    Germany
    8
    just noticed that the blinking cursor under the last line freezes on 4.15 boot. Nothing i can do from there on, except force shutdown with four seconds on power button.
    Feb 2018
    Germany
    8
    Ok i was optimistic as there was an upgrade to kernel 4.15.4 today, but unfortunatly the problem persists -> boot freezes .
    Jul 2004
    Wake Forest, NC
    64
    1,434
    I am experiencing this same problem on an Acer Aspire One netbook with AMD C50 processor. The boot hangs at a message about starting a job for a file system check and just sits there with a timer counting up with no limit. If I elect to start the 4.14.16 kernel, the boot completes as expected. After I post this, I am off to Redhat Bugzilla to see what I can find out about this.
    StephenH
    "We must understand the reality that just because our culture claims certain things are true it does not mean they are!" --M. Liederbach
    http://pilgrim-wanderings.blogspot.com
    Feb 2018
    Turin
    Similar issue here,
    at first kernel 4.15 did not boot (Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz processor and Intel Corporation Skylake GT2 [HD Graphics 520]) with the same error. Now, I suppose after a mesa update, boots but it goes to suspend mode while loading or just before loading DE.
    Regards
    MM
    Jul 2004
    Wake Forest, NC
    64
    1,434
    I suspect the mesa update fixed something. My Acer Aspire One 722 now boots properly. That was strange though.
    StephenH
    Feb 2018
    Germany
    8
    Well i'm sorry to say it, but ... i solved my problem by switching to another distribution which uses in testing Kernel 4.16 and Mesa 17.3.6. No Xorg-config in /etc/X11/xorg.conf.d so the kernel determines which gpu-driver is loaded automatically and it now works :
    inxi -F claims at least:
    Graphics: Card: Advanced Micro Devices [AMD/ATI] Vega [Radeon Vega 8 Mobile]
    Display Server: N/A drivers: ati,amdgpu (unloaded: modesetting,radeon) tty size: 188x27
    And i now got hardware acceleration .
    Feb 2018
    Germany
    8
    Quote Originally Posted by StephenH
    That might very well the case. But i cannot test it anymore ... sorry.
    Feb 2018
    Holland
    3
    I have now installed the last kernel, but I still have the same problem. Think I'll try another distro ...
    Jul 2004
    Wake Forest, NC
    64
    1,434
    The 4.15.6 kernel also freezes. Back to 4.14.16 and exclude kernels from update for the time being.
    StephenH
    Feb 2018
    Germany
    8
    Perhaps some of you will help this:
    I still get these boot freezes sometimes but then i just have to try it again (sometimes up to five times) and it will boot at least. At least on my 4.16 Kernel and Mesa 17.3.6.
    Also some say it should help to disable C6 state in the BIOS and adding "rcu_nocbs=0-7" as a kernel boot option for the 2400G as it has eight threads and "rcu_nocbs=0-3" for the 2200G as it has only 4 threads.
    May 2006
    Porto, Portugal
    48
    70
    Is everyone with these problems using similar hardware?
    I have a AMD FX6300 with a (very old...) Nvidia 9800 GT graphics card, on a gigabyte 970 motherboard and kernel 4.15.6-300 boots normally.
    Very interested in this thread, as I'm starting my Rizen build...
    Feb 2018
    Germany
    8
    I'm running a new Ryzen 5 2400G APU.
  1. Fedora 23 - Not able to boot after kernel upgrade
    By gautamsathe in forum Installation, Upgrades and Live Media
    Last Post: 15th December 2016, 10:24 AM
    Fedora 20 won't boot into kernel 3.14.9
    By CuddlyPython in forum Using Fedora
    Last Post: 7th July 2014, 04:38 PM
  3. Fedora 18 won't boot latest kernel 3.9
    By jcnewton in forum Hardware & Laptops
    Last Post: 7th June 2013, 09:50 PM
  4. Replies: 8
    Last Post: 2nd November 2008, 03:11 PM
  5. Cannot boot the kernel-Fedora 7
    By petercn in forum Installation, Upgrades and Live Media
    Last Post: 8th October 2007, 05:49 AM
