Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Ventura, CA
    397
    Re: trying to get commands work with grub 2 bootable via pen drive
    Don't worry. The iso works fine despite the error messages.
    Feb 2018
    Usa
    28
    Ok, I still want to replace kernel file with newer one.
    Ventura, CA
    397
    Well, you might have to create a kickstart via livemedia-creator and mock and then create a fedora respin (you can load any packages you want, and your iso will be completely up-to-date (there are other ways to upgrade your kernel but these are not the best way to do this). This process is a bit complicated and time-consuming, so I'm not sure that this would be of interest to you. Here is some useful information which includes the url of the fedora wiki: https://forums.fedoraforum.org/showt...-s-work-around
    If you go this route and have problems, first google and then open another thread on this forum (I would try to help you the best I can if you need help).
    The nice thing about this process is that you can download a fully updated, fully configured (the packages that you want on your system) to any and all (almost all) machines in a relatively short time. You will also have a portable,fully updated, fully configured, very secure computer (your usb drive) that you can start up on other computers.
  4. #19
    Feb 2018
    Usa
    28
    Thank you. I am going to try that one next. I should modify command line in my post so anyone can copy that command line anytime. I will create a new thread next. I will name the thread as "iso with new kernel" or you can give me a suggestion for the thread name. Thank you again.
    He or she should check this first before adding ****-**** in command line for grub 2.
    sudo blkid
  5. #20
    Ventura, CA
    397
    Very good. You might want to name the thread "Updating fedora iso with newest kernel using Livemedia-creator" or something similar (the shorter, the better).
    Again, look through the fedora lorax livemedia-creator wiki before you do anything.
  1. Grub Complains About Outb Commands in Grub.cfg
    By joncr in forum Installation, Upgrades and Live Media
    Last Post: 12th August 2013, 08:32 PM
  2. How to make a drive non-bootable?
    By dcass in forum Using Fedora
    Last Post: 4th August 2011, 04:58 AM
  3. Installing FC6 without bootable CD drive
    By mrbelfry in forum EOL (End Of Life) Versions
    Last Post: 8th March 2007, 12:16 AM
  4. GRUB commands
    By massimomm in forum Using Fedora
    Last Post: 2nd April 2006, 07:29 PM
