FC 27 Add printer tool doesn't detect USB printer
    Aug 2004
    4,083
    In a recently installed and update FC 27 XFCE spin installation, the printer adminstration tool doesn't detect a printer (Laserjet Peo M1212nf) attached to a USB port. It only offers the choice of connecting a printer to a serial port and after using that option, the printer doesn't print.
    The M1212nf shows up in the list of HP printers. The command line sane-find-image detects the machine (since it is also a scanner).
    Edit: I tried another printer (HP Lasetjet 1536dnf) and had no problem adding it and printing to it.
    I conclude the M1212nf can't be used with FC 27 without taking extraordinary measures. There are posts on the web about people getting it to work as a network printer. I didn't find any reports of it working as a local printer.
    "Never let the task you are trying to accomplish distract you from the study of computers."
    Ventura, CA
    427
    Re: FC 27 Add printer tool doesn't detect USB printer
    Have you tried to locate the printer on the cups website (localhost:631)? If it shows up on the cups website, then try to add it. Of course, cups must be installed on your system (I would assume it is already installed; if not, install it)
    Nov 2018
    Linux (Fedora) Firefox 63.0
    Quote Originally Posted by donatom
    I had this problem with the Fedora 29 desktop. The settings application -> Printers did not see the printer but the CUPS interface found it. Everything set up correctly. Thanks.
    Funny, my old Fedora 14 install found and configured the printer automatically when I plugged in the USB cable.
  1. HPLIP does not detect usb printer after update
    By twidlerjohn in forum Hardware & Laptops
    Last Post: 31st March 2017, 12:34 AM
  2. fedora 16 (64) - where is printer configuration tool
    By rholme in forum Installation, Upgrades and Live Media
    Last Post: 31st May 2012, 12:42 AM
  3. Replies: 2
    Last Post: 16th December 2008, 05:46 AM
  4. How get Fedora to detect a printer in the network?
    By emamm in forum Installation, Upgrades and Live Media
    Last Post: 24th July 2006, 05:10 AM
  5. FC3 no usb support...can't detect printer or flash drive
    By mb77 in forum Hardware & Laptops
    Last Post: 7th January 2005, 07:46 AM
