openvpn connectivity problems.
Results 1 to 10 of 10
    Feb 2018
    Florida
    13
    Hi all,
    I am trying to connect via VPN to google.com using a NordVPN server but no luck.
    In chrome it says:
    This site canít be reached
    www.google.com server IP address could not be found
    Try checking proxy, firewall, DNS configuration
    DNS_PROBE_FINISHED_BAD_CONFIG
    Not sure where to go from here because I have little knowledge of how the DNS settings work.
    These are the directions I used to set up the openvpn daemon and the NordVPN server.
    https://nordvpn.com/tutorials/linux/openvpn/
    Would like to learn more about networking on linux, if you have any resources that would help me accomplish that please link even if you don't have a solution for my issue.
    Jan 2010
    7,318
    Re: openvpn connectivity problems.
    Where in the tutorial do you get the error? Generally, if you are given credentials, such as they give you, something like
    sudo openvpn ./<configurationfile> will prompt for password (possibly user name too) and once you enter them, it will work. It generally requires sudo privilege as it creates a virtual interface.
    Feb 2018
    Florida
    13
    I do not receive any errors during the tutorial. The only error I receive is when I try connecting to a website on Chrome. I did the tutorial after using
    su
    after entering "su" it prompts me for a password which I enter and it gives me root access. After gaining root access I proceeded with the tutorial steps (not needing sudo in each command anymore.)
    After entering
    openvpn <configuration file>
    I do input my credentials and it goes through some processes on the terminal which I do not understand yet but last time I encountered the problem it set something like "AUTHENTICATED" I believe.
    FYI: After rebooting it automatically establishes a normal wifi connection (like the one I am using right now)
    Jan 2010
    7,318
    If it says authenticated, that sounds as if it's connecting. After that, can you try running
    ip add sh
    in another terminal? See if it shows the VPN interface.
    Feb 2018
    Florida
    13
    What does that command do (I like to know what commands do before I input them)? I couldn't find it in this quick guide https://access.redhat.com/sites/defa..._jcs_print.pdf
    Jan 2010
    7,318
    You're right, I should have explained that and it's a good question on your part. The ip command is used instead of ifconfig, these days. Often, one can abbreviate the options.
    In this case it's ip (the command) sh (for show) ad (for address, or maybe addresses).
    This will do what the old ifconfig command did, show your interfaces and their addresses if they have any. I have a somewhat old page which gives some of the common ip commands at http://srobb.net/ip.html
    Feb 2018
    Florida
    13
    I found a tcp server that connected and shows at the bottom of the terminal:
     Wed Feb 14 14:41:14 2018 Initialization Sequence Complete
    Then I “ip address show” in a different terminal.
    I can confirm that there is a new interface named “tun0”.
    But on the second line it shows
    link/none
    if that means anything.
    Jan 2010
    7,318
    Hrrm. Well, tun0 is what you'd expect to see, but it should show an address. It seems like you're doing it right, perhaps they have a support channel, since this appears to be something you've bought.
    Feb 2018
    Florida
    13
    Thanks for your help smr54, I contacted customer support and will update here to let you know if it is resolved or not.
    We are in this together; keep it together. Thanks
    Jan 2010
    7,318
    Sorry I couldn't be of more help. In my experience (both work and helping friends) it's usually been as straightforward as their docs make it seem.
    No internet connectivity after openvpn setup
    By Tmando in forum Using Fedora
    Last Post: 13th February 2018, 02:51 PM
  2. Connectivity Problems with OpenVPN
    By brad_c6 in forum Servers & Networking
    Last Post: 1st January 2009, 01:52 AM
  3. Connectivity Problems
    By evanthes in forum Servers & Networking
    Last Post: 16th April 2008, 02:16 PM
  4. QWEST DSL connectivity problems
    By mleffers in forum Servers & Networking
    Last Post: 7th July 2006, 01:59 AM
  5. Wierd connectivity problems - FC4
    By IvanAndersen in forum Servers & Networking
    Last Post: 5th June 2006, 11:29 AM
