Hi all,
I changed Ubuntu 12 to Fedora 27 recently on my computer. My old
home
folder is an individual hard drive, so after I installed Fedora 27, I removed new
home
folder and mount this hard drive onto an empty
home
folder. I changed the owner and group recursively, and changed the
.ssh
folder to 700, and
authorized_keys
to 600 with
chmod
command. However, I still could login with my public keys. Here is the verbose information:
 OpenSSH_7.2p2 Ubuntu-4ubuntu2.4, OpenSSL 1.0.2g  1 Mar 2016
debug1: Reading configuration data /home/myusername/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to *.* [*.*.*.*] port 22.
debug1: Connection established.
debug1: identity file /home/myusername/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/myusername/.ssh/id_rsa-cert type -1
debug1: identity file /home/myusername/.ssh/id_dsa type -1
debug1: identity file /home/myusername/.ssh/id_dsa-cert type -1
debug1: identity file /home/myusername/.ssh/id_ecdsa type -1
debug1: identity file /home/myusername/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/myusername/.ssh/id_ed25519 type -1
debug1: identity file /home/myusername/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6
debug1: match: OpenSSH_7.6 pat OpenSSH* compat 0x04000000
debug1: Authenticating to *.*:22 as 'myusername'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: *****
The authenticity of host '*.* (*.*.*.*)' can't be established.
ECDSA key fingerprint is SHA256:****
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '*.*' (ECDSA) to the list of known hosts.
Warning: the ECDSA host key for '*.*' differs from the key for the IP address '*.*.*.*'
Offending key for IP in /home/myusername/.ssh/known_hosts:41
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,null>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,gssapi-keyex,gssapi-with-mic,password
debug1: Next authentication method: gssapi-keyex
debug1: No valid Key exchange context
debug1: Next authentication method: gssapi-with-mic
debug1: Unspecified GSS failure.  Minor code may provide more information
No Kerberos credentials available
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/myusername/.ssh/id_rsa
debug1: Trying private key: /home/myusername/.ssh/id_dsa
debug1: Trying private key: /home/myusername/.ssh/id_ecdsa
debug1: Trying private key: /home/myusername/.ssh/id_ed25519
debug1: Next authentication method: password
myusername@*.*'s password:
debug1: Authentication succeeded (password).
Authenticated to *.* ([*.*.*.*]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Sending environment.
debug1: Sending env LANG = en_US.UTF-8
In addition, after I login with password, I got an error message:
-bash: /home/myusername/softwares: syntax error: operand expected (error token is "/home/myusername/softwares")
Do you have any ideas to solve these? Thanks!!
