Fedora 27 does not allocate much space for home folder
Results 1 to 6 of 6
    Oct 2012
    Scotland
    3
    Dear everyone,
    I have installed Fedora 27 on a new machine, with a Samsung 850 EVO 250 GB.
    When migrating my home drive from my old pc (I used Deja dup), it complains that I don't have enough space on my home drive. All of my fiels on my previous PC total to 131 GB.
    On the new installation, it says I only have 52.6 GB Total on localhost.localdomain, and 46.6GB available.
Name:	Screenshot from 2018-02-13 10-50-00.png
    I have installed GParted, but I'm not really sure of how to use it to increase my home partition, or if GParted IS the right tool for me.
    Can anyone help me to increase my home partition, please? I have been stuck on this for two days. Most of the solutions I have seen, refer to virtual machines.
    Thanks,
    Lucas
    EDIT: I have run the following command:
    sudo df -h -x tmpfs -x devtmpfs
    Filesystem Size Used Avail Use% Mounted on
    /dev/mapper/fedora-root 49G 5.5G 41G 12% /
    /dev/sda1 976M 177M 732M 20% /boot
    /dev/mapper/fedora-home 176G 174M 167G 1% /home
    Dec 2008
    125
    Re: Fedora 27 does not allocate much space for home folder
    Hi Lucast -
    I have found that the default partitioning scheme in Redhat flavors of Linux is pretty lame. I always override it with my own config. Of course, this requires a reformat-reinstall in your case, but it might be worth the effort if you have not got a lot of time invested in setting up your system.
    In my opinion - LVM is an answer that is searching for a problem. It is true that you can expand (but not contract) LVM volumes relatively easily. When was the last time you needed to do that? And stretching an LVM volume across multiple physical drives is painful. You are better off to buy a bigger hard drive and transfer the existing system using CloneZilla.
    Bill Gee
    I prefer to allocate 2GB for /boot, 4GB for swap and the rest for /. Use real partitions, not LVM.
    911
    my $0.02:
    I never use LVM , it introduces a lot of problems when there is encryption.
    I always do this:
    swap=2x RAM
    / 60GB
    (No /boot partition, as it tends to fill up when upgrading kernels)
    the rest I leave empty, until after install
    after install I create a new partition in the empty space, and encrypt it (but I don't add it to /etc/fstab on purpose)
    once encrypted, I then do in a terminal : mv /home /home.old ; mkdir /home ; chmod 755 /home
    then I manually mount the encrypted partition as /home
    that's it.
    This gives me the ability to go through airports with plausible deniability, and without the laptop asking me for my encrypted partition password on boot, which would land you in jail if you don't tell it.
    Apr 2005
    Finland
    5,073
    You have 167 GB free on the /home filesystem, that should be enough to unpack your files. Make sure you're transferring to files to the /home filesystem and not to the root FS.
    Oct 2012
    Scotland
    3
    Thank you all.
    Yes, second install, I was able to get a lot more space.
    Anaconda, as an installer, has gone down in terms of user friendliness. I prefer the old option when it asked if I wanted to delete existing installations and do a fresh install, or something like that.
    Maryland, US
    7,333
    ...(No /boot partition, as it tends to fill up when upgrading kernels)
    That's easy to fix, just set installonly_limit in dnf to 3 or 4 so it can't fill up
  1. Replies: 2
    Last Post: 19th December 2012, 05:14 AM
  2. Allocate more Hard Drive Space
    By SenorRude in forum Using Fedora
    Last Post: 13th December 2012, 12:36 PM
  3. [SOLVED]
    Home folder eating up all free disk space
    By ciaranw in forum Using Fedora
    Last Post: 9th February 2011, 04:51 PM
  4. Need more space in my home folder
    By geeve420 in forum Using Fedora
    Last Post: 19th January 2011, 12:59 AM
  5. /dev folder missing ... Server refused to allocate pty
    By fed.linuxgossip in forum Using Fedora
    Last Post: 7th June 2007, 05:15 PM
