    Aug 2008
    Metz, FRANCE
    43
    59
    Exclamation installation of fedora 26 fails due to partition problems
    hi,
    I would like to configure the installation of fedora 26 but I have some issues. I have 2 disks:
    sdb which is a 120Go SSD disk
    sda, a 1To normal sata disk
    I have got windows installed on the SSD disk.
    I want to put the /home directory in sda (100Go should suffice) and everything else in sdb. so I configured the fedora installer as follow:
    but this configuration seems not be good for fedora : the installer says that "you have to create a new filesystem on the root device"... I don't understand what is it complaining about.
    thank you
    Aug 2008
    Metz, FRANCE
    43
    59
    Re: installation of fedora 26 fails due to partition problems
    ok, I found the answer : I had to give a name to the root partition, in addition to mount it as "/"
  1. Fedora 15 USB DVD ISO Installation Fails
    By ole_ersoy in forum Installation, Upgrades and Live Media
    Last Post: 27th August 2011, 12:23 AM
  2. Fedora 11 installer fails when making a partition
    By countryjake in forum Installation, Upgrades and Live Media
    Last Post: 12th June 2009, 02:47 AM
  3. FC7 Installation - gparted, ntfs, LVM partition problems
    By dlm4ut in forum Installation, Upgrades and Live Media
    Last Post: 27th June 2007, 09:31 PM
  4. newbie with installation problems - partition and anaconda
    By LeftHand in forum Installation, Upgrades and Live Media
    Last Post: 16th November 2005, 10:27 AM
  5. Fedora core 4 installation fails
    By 1inxs in forum Installation, Upgrades and Live Media
    Last Post: 28th October 2005, 09:31 PM
