2nd Hard Drive with Fedora
Results 1 to 7 of 7
    Oct 2011
    11
    I have a T420 Thinkpad with Windows 10 on it. I'm replacing my cd drive with another hard drive. I would like to install Fedora on it, but I don't want it to affect the Windows drive. I would prefer to hit F12 at boot and choose Fedora rather than have grub take over boot options. Is this possible?
    Apr 2009
    central NY, USA
    1,105
    Re: 2nd Hard Drive with Fedora
    So, your issue is WHICH interface gives you the boot options?
    Change - the only constant.
    Oct 2011
    11
    It actually worked out like I hoped. It still defaults to Win10 and I can hit F12 to choose Fedora during boot. Fedora didn't change the boot order during installation
    5,225
    From the bios you can select which of the two drives to use as the boot drive. If you used the bios to set the boot drive to the /dev/sdb, then your system will boot the Fedora system and subsequently you respond to grub to select which operating system to boot.
    grub allows you to even set the highlighted drive to be the second one, and to not default to the /dev/sda .
    Oct 2011
    11
    Thanks!
    I'm quickly becoming a fan of Fedora. Mostly I have used Ubuntu and Debian in the past.
    5,225
    One more item
    If you boot the /dev/sdb to make sure your /dev/sdb is actually the boot drive, run the following from the /dev/sdb drive
    sudo grub2-install /dev/sdb
    it will install the boot code into the /dev/sdb mbr and setup grub on the /dev/sdb The /boot/grub2/grub.cfg will be updated and it will contain entries for both operating systems.
    Oct 2011
    11
    Thanks again! Much appreciated!
  1. Using internal hard drive as external hard drive
    By tech291083 in forum Wibble
    Last Post: 9th December 2017, 05:15 PM
  2. EIDE hard drive recognized as sda hard drive
    By jfalknor in forum Installation, Upgrades and Live Media
    Last Post: 1st May 2010, 08:28 PM
  3. Which hard drive and which Fedora?
    By jktaber in forum Using Fedora
    Last Post: 30th April 2009, 03:03 PM
  4. Installing to a USB Flash Drive and using the drive and a normal hard drive
    By beeball in forum Installation, Upgrades and Live Media
    Last Post: 23rd March 2008, 05:45 AM
  5. Replies: 20
    Last Post: 5th February 2006, 05:53 AM
