    Feb 2018
    Portugal
    Fedora 27 not shutdown
    Hi, i recently installed fedora 27 and it works fine but when i try to shutdown it shows the following message:
    wlp3so: failed to remove key from hardware, and some times shows a different message witch is
    ACPI region does not cover the entire command / response buffer
    does any one know how to solve this?
    Thank you
    Feb 2018
    Australia
    3
    Re: Fedora 27 not shutdown
    I have the same problem
    Ventura, CA
    250
    I'm not sure what the problem is, but this command in terminal should shutdown your system (do this as super-user or use "sudo" if you've set it up):
    # poweroff
    Also you might upgrade your system (which you should be doing every day) with "sudo dnf upgrade" in the terminal.
    Feb 2018
    Australia
    3
    thank you friend
  1. inconsistent daemon shutdown on OS shutdown
    By nickdu in forum Programming & Packaging
    Last Post: 24th April 2016, 11:25 PM
  2. Replies: 1
    Last Post: 18th March 2008, 06:00 PM
  3. Replies: 5
    Last Post: 19th November 2007, 12:00 PM
  4. Replies: 2
    Last Post: 12th February 2007, 07:07 PM
  5. How to hide FC6 shutdown messages or use shutdown spash
    By renjoyhenry in forum Using Fedora
    Last Post: 5th November 2006, 06:09 AM
