dnf very slow when system is installed on USB key
Results 1 to 6 of 6
    Jan 2012
    Italy
    3
    I've installed Fedora on a USB key, not a live edition; it works with a decent speed but dnf upgrade is very slow.
    dnf is fast as expected downloading RPM files but it's very slow during RPM installation.
    Monitoring with top I've noted a load about 4.0 to 4.5, but CPU is always under 4%.
    Any idea about this slowness?
    Thanks in advance
    Oct 2011
    1,825
    Re: dnf very slow when system is installed on USB key
    Perhaps USB stick write speed is slow. It might be fine on continuous file, but may cough on large amount of smaller files.
    Oct 2011
    11
    USB sticks vary. Some are simply not good to run an OS on. I'm using Fedora 27 on a Sandisk USB right now and it works great. I avoid the tiny USB sticks as they get too hot, burned one up not long ago.
    6,218
    sandisk ultra fit usb 3.0 64GB works great for running an OS from and heat dissipates reasonably well. the read and write speeds are good, it does get warm but not too hot in operation.
    911
    This usually happens when Delta RPM is running, which has to basically go file by file and check what needs changed/patched/updated/modified , so it has to read and write and verify.
    There is a new M.2 NVMe over USB (StarTech.com M.2 to SATA SSD Enclosure - USB 3.0 with UASP)
    That may give you the speed you need. But look at its picture you will see that it needs some air flow.
    Oct 2011
    11
    That is what I burned up I like the bigger Sandisk usb sticks as they don't get warm and hold up pretty well.
    f17 alpha tc2, update brings a slow system (really slow...)
    By rtguille in forum F17 Development Forum
    Last Post: 23rd February 2012, 09:06 PM
  2. Replies: 25
    Last Post: 11th July 2007, 07:58 AM
  3. just installed fc6, internet is really slow
    By timmers71elm in forum Using Fedora
    Last Post: 18th November 2006, 01:59 PM
  4. Installed FC 3 - Internet now very slow
    By Alfred in forum Servers & Networking
    Last Post: 23rd February 2005, 03:51 PM
  5. Installed FC 3 - Internet now very slow
    By Alfred in forum Using Fedora
    Last Post: 22nd February 2005, 05:28 AM
