    Jan 2018
    California
    28
    Graphicsd issues? F27 and three screens
    This is a "out of the box install"
    I was wondering is anyone else is experiencing these things.
    1)
    I often like to stretch the video display across three screens to "black out" the light of the other two when I watch a movie.
    VLC locks up mid stretch every time I try to do that. VLC or Fedora 27? The arrow and bar of extending a screen freezes and I have to manually reboot
    2)
    Importing torrents to qbittorent hits a snag. At this point qtorrent is now rendered useless. Removing and re-installing dose not fix things.
    It happened as I tried to import torrents. At first selecting all the torrents 200+ qbittorent the system froze directly. Then after rebooting I was able to process one "limited number" of torrents possibly about 10 to 15. If I tried to process another limited batch I could not. So I rebooted and was able to repeat. The third reboot and restarting qbittorent changed nothing. After two reboots and processing a limited number of torrents rebooting no longer worked and the system froze. Rebooting again, qbittorent now doesn't function at all including the x in the upper right hand to kill it.
    qbitorrent is now inert. It will not download or upload however it will fetch torrent metadata.
    So I thought to ask if anyone else has experienced these things.
    Havant
    178
    Re: Graphicsd issues? F27 and three screens
    Maybe updating rb_libtorrent will help
    sudo dnf --enablerepo=u*g update rb_libtorrent\*
    also post the output for
    qbittorrent
    Jan 2018
    California
    28
    I updated I see nothing different. I also thank you for your help.
    I am inexperienced so how do I output for qbittorent.
    Also I see a hardware error nouveau 0000:01:00:0 bus: MMIO write of 800000fa FAULT at 10eb14 [ IBUS ] I believe that has to do with graphics?
    The ability to close window and exit program works now.
    Jan 2018
    California
    28
    I switched to Transmission.
    do all Fedora versions support multiple screens/touch screens
    By CalmWind in forum Using Fedora
    Last Post: 6th May 2014, 12:44 AM
  2. using 2 screens with Fed 14
    By Pedroski in forum Using Fedora
    Last Post: 16th September 2011, 12:41 AM
  3. not have screens :S
    By MalMen in forum Using Fedora
    Last Post: 26th December 2005, 12:07 PM
  4. using 2 screens.
    By Steve T in forum Hardware & Laptops
    Last Post: 10th February 2005, 04:48 AM
