Results 1 to 11 of 11
    Dec 2008
    204
    Fedora 27: Wrong Audio Hardware Listed?
    Hi there,
    I am using super old notebook "Compaq Presario F763NR" with Fedora 27 Cinnamon Spin on it. From the picture below, I don't recall see any of those in the past. I shouldn't have any Nvidia Sound Tech with this notebook This notebook has been used with Ubuntu, Linux Mint, and Fedora for the longest time, and I have not seen such the list.
    I pulled the list in the picture from VLC 3.0 RC3 menu. I hope someone can help. I don't think Nvidia Driver 304:137 can make any sound either :| My kernel is Linux 4.14.11-300.fc27.x86_64. Where did such the list come from?
    I also think my on board sound should be Realtek.
    Havant
    178
    Re: Fedora 27: Wrong Audio Hardware Listed?
    post
    aplay --list-devices
    734
    I have found that installing pavucontrol and running it , under System-> Sound & Video -> Pulseaudio Volume Control
    and then selecting from the "Configuration" tab, where you want your sound to come out/in to/from, worked wonders for me.
    Dec 2008
    204
    Quote Originally Posted by leigh123linux
    post
    Here is the result. I really can't recall I have any Nvidia sound device with this notebook Do you happen to know, how the word "Nvidia" get in there?
    $ aplay --list-devices
    **** List of PLAYBACK Hardware Devices ****
    card 0: NVidia [HDA NVidia], device 0: CX20561 Analog [CX20561 Analog]
    Subdevices: 0/1
    Subdevice #0: subdevice #0
    card 0: NVidia [HDA NVidia], device 1: CX20561 Digital [CX20561 Digital]
    Subdevices: 1/1
    Thank you again.
    Dec 2008
    204
    Just like I remember, I have not seen the word "Nvidia" in the past.
    How should I progress this? Is there a bug in ALSA or something? Should I let ALSA know? I have no problem detected with any sound currently, however.
    Thank you.
    734
    Quote Originally Posted by Sethanath
    Thank you.
    So, everything is working now ? if so, then merry xmas, happy new year, wash and wear.
    Dec 2008
    204
    Everything work since the beginning of the post. I only wonder how VLC 3.0 get the word "Nvidia" on their menu. The same way for ALSA, it has "Nvidia" word shown. I have installed so many Linux distribution on this notebook, only Fedora 27 has the word "Nvidia" used.
    I hope you can teach me.
    734
    duhhh, gotcha now, my stupidity precluded me from undersitting your post.
    what does "lspci" (or lspci -v) say ? any word about nvidia ?
    Dec 2007
    Australia
    1,725
    That notebook "Compaq Presario F763NR" runs an nVidia card: "nVIDIA GeForce 7000M with up to 287MB shared memory" according to the HP specs site on it, and that card has an "audio feature" of the 7000M series: "Enjoy premium HD audio, storage and communications performance without sacrificing battery life with NVIDIAŽ PowerMizer™ SX technology" according to the nVidia specs site on it .
    Dec 2008
    204
    Here it is.
    $ lspci -v
    00:00.0 RAM memory: NVIDIA Corporation MCP67 Memory Controller (rev a2)
    Subsystem: Hewlett-Packard Company Device 30ea
    Flags: bus master, 66MHz, fast devsel, latency 0, NUMA node 0
    Capabilities: <access denied>
    00:01.0 ISA bridge: NVIDIA Corporation MCP67 ISA Bridge (rev a2)
    00:01.1 SMBus: NVIDIA Corporation MCP67 SMBus (rev a2)
    Flags: 66MHz, fast devsel, IRQ 10, NUMA node 0
    I/O ports at 3080 [size=64]
    I/O ports at 3040 [size=64]
    I/O ports at 3000 [size=64]
    Kernel driver in use: nForce2_smbus
    Kernel modules: i2c_nforce2
    00:01.2 RAM memory: NVIDIA Corporation MCP67 Memory Controller (rev a2)
    Flags: 66MHz, fast devsel, NUMA node 0
    00:01.3 Co-processor: NVIDIA Corporation MCP67 Co-processor (rev a2)
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 11, NUMA node 0
    Memory at f6200000 (32-bit, non-prefetchable) [size=512K]
    00:02.0 USB controller: NVIDIA Corporation MCP67 OHCI USB 1.1 Controller (rev a2) (prog-if 10 [OHCI])
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 18, NUMA node 0
    Memory at f6486000 (32-bit, non-prefetchable) [size=4K]
    Kernel driver in use: ohci-pci
    00:02.1 USB controller: NVIDIA Corporation MCP67 EHCI USB 2.0 Controller (rev a2) (prog-if 20 [EHCI])
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22, NUMA node 0
    Memory at f6489000 (32-bit, non-prefetchable) [size=256]
    Kernel driver in use: ehci-pci
    00:04.0 USB controller: NVIDIA Corporation MCP67 OHCI USB 1.1 Controller (rev a2) (prog-if 10 [OHCI])
    Memory at f6487000 (32-bit, non-prefetchable) [size=4K]
    00:04.1 USB controller: NVIDIA Corporation MCP67 EHCI USB 2.0 Controller (rev a2) (prog-if 20 [EHCI])
    Memory at f6489400 (32-bit, non-prefetchable) [size=256]
    00:06.0 IDE interface: NVIDIA Corporation MCP67 IDE Controller (rev a1) (prog-if 8a [Master SecP PriP])
    [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
    [virtual] Memory at 000003f0 (type 3, non-prefetchable)
    [virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
    [virtual] Memory at 00000370 (type 3, non-prefetchable)
    I/O ports at 30c0 [size=16]
    Kernel driver in use: pata_amd
    Kernel modules: pata_amd, pata_acpi, ata_generic
    00:07.0 Audio device: NVIDIA Corporation MCP67 High Definition Audio (rev a1)
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 21, NUMA node 0
    Memory at f6480000 (32-bit, non-prefetchable) [size=16K]
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel
    00:08.0 PCI bridge: NVIDIA Corporation MCP67 PCI Bridge (rev a2) (prog-if 01 [Subtractive decode])
    Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
    I/O behind bridge: None
    Memory behind bridge: f6100000-f61fffff [size=1M]
    Prefetchable memory behind bridge: None
    00:09.0 IDE interface: NVIDIA Corporation MCP67 AHCI Controller (rev a2) (prog-if 85 [Master SecO PriO])
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 23, NUMA node 0
    I/O ports at 30f0 [size=8]
    I/O ports at 30e4 [size=4]
    I/O ports at 30e8 [size=8]
    I/O ports at 30e0 [size=4]
    I/O ports at 30d0 [size=16]
    Memory at f6484000 (32-bit, non-prefetchable) [size=8K]
    Kernel driver in use: ahci
    Kernel modules: pata_acpi, ata_generic
    00:0a.0 Ethernet controller: NVIDIA Corporation MCP67 Ethernet (rev a2)
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 24, NUMA node 0
    Memory at f6488000 (32-bit, non-prefetchable) [size=4K]
    I/O ports at 30f8 [size=8]
    Memory at f6489c00 (32-bit, non-prefetchable) [size=256]
    Memory at f6489800 (32-bit, non-prefetchable) [size=16]
    Kernel driver in use: forcedeth
    Kernel modules: forcedeth
    00:0c.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2) (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0, NUMA node 0
    Bus: primary=00, secondary=04, subordinate=05, sec-latency=0
    I/O behind bridge: 00004000-00004fff [size=4K]
    Memory behind bridge: f2000000-f3ffffff [size=32M]
    Prefetchable memory behind bridge: 00000000f0000000-00000000f1ffffff [size=32M]
    Kernel driver in use: pcieport
    Kernel modules: shpchp
    00:0d.0 PCI bridge: NVIDIA Corporation MCP67 PCI Express Bridge (rev a2) (prog-if 00 [Normal decode])
    Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
    Memory behind bridge: f6000000-f60fffff [size=1M]
    00:12.0 VGA compatible controller: NVIDIA Corporation C67 [GeForce 7000M / nForce 610M] (rev a2) (prog-if 00 [VGA controller])
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 16, NUMA node 0
    Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
    Memory at d0000000 (64-bit, prefetchable) [size=256M]
    Memory at f4000000 (64-bit, non-prefetchable) [size=16M]
    [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
    Kernel driver in use: nvidia
    Kernel modules: nouveau, nvidia
    00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
    Flags: fast devsel, NUMA node 0
    00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
    00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
    00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
    Kernel driver in use: k8temp
    Kernel modules: k8temp
    02:05.0 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
    Flags: bus master, medium devsel, latency 64, IRQ 7, NUMA node 0
    Memory at f6100000 (32-bit, non-prefetchable) [size=256]
    Kernel driver in use: sdhci-pci
    Kernel modules: sdhci_pci
    02:05.1 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 12)
    Memory at f6100400 (32-bit, non-prefetchable) [size=256]
    02:05.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
    Memory at f6100800 (32-bit, non-prefetchable) [size=256]
    Kernel driver in use: r592
    Kernel modules: r592
    02:05.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12)
    Flags: bus master, medium devsel, latency 64, IRQ 10, NUMA node 0
    Memory at f6100c00 (32-bit, non-prefetchable) [size=256]
    03:00.0 Ethernet controller: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) (rev 01)
    Subsystem: Hewlett-Packard Company AR5BXB63 (Foxconn) 802.11bg Mini PCIe NIC
    Flags: bus master, fast devsel, latency 0, IRQ 19, NUMA node 0
    Memory at f6000000 (64-bit, non-prefetchable) [size=64K]
    Kernel driver in use: ath5k
    Kernel modules: ath5k
    Dec 2008
    204
    Quote Originally Posted by nsnbm
    When I read the manual long time ago, I also saw those terms "Depend on selected model", and I thought there might not be everything they mention. For example, I don't have any web cam and I can only allcatate 128 MBs from RAM to Video. I also have their latest BIOS software installed. But at this point, I am happy I do have HD Audio.
    Thank you everyone.
  1. Replies: 5
    Last Post: 17th February 2012, 06:27 AM
  2. Audio hardware/VIA VT1818
    By AJWR11 in forum Hardware & Laptops
    Last Post: 13th November 2011, 12:53 AM
  3. [SOLVED]
    VT1708S HD Audio Hardware not detected
    By Dunc4n in forum Hardware & Laptops
    Last Post: 8th January 2011, 09:11 AM
  4. Some thing wrong on my display hardware ..?
    By The Mixer in forum Hardware & Laptops
    Last Post: 2nd January 2010, 06:35 PM
