Fedora 27 not updating on Power off
    Oct 2009
    23
    For the last few weeks, Fedora 27 has not indicated that there are any updates to apply. Normally it will allow me to reboot, install updates, and then either power off or restart. When I ran a dnf update, it listed hundreds of updates available, so I updated manually. There is a disconnect somewhere. The software app says that it is unable to download updates, so that it probably why it is not offering any.
    I am running Fedora 27 4.14.8-300.fc27.x86_64 #1 SMP. Has anyone else noticed this behavior, and have a fix for it?
    5,612
    Re: Fedora 27 not updating on Power off
    From your description, i think you are using the GNOME software tool. It may not show or it may be locked up because a previous run did not complete.
    do install dnfdragora as sudo dnf install dnfdfagora
    dnfdragora is a graphical interface to use with Fedora. If you are comfortable with the comand line option, use dnf.
    sudo dnf upgrade
    Oct 2009
    23
    sudo dnf upgrade
    Unfortunately, that did not resolve the issue. When I run the Software package under Gnome, I get the error "Unable to download updates." I've looked through the log files, and I don't see anything which indicates why it can't download updates.
    5,612
    Please switch to terminal mode and run
    sudo dnf update
    or
    sudo dnf upgrade.
    upgrade is the same as as update
    Let us now if there are error messages. Paste a few lines from one run here.
    Oct 2009
    23
    sudo dnf update
    or
    sudo dnf upgrade.
    I was able to install dnfdragora, and I can manually update my packages. However, I still do not get an option when shutting down that packages are available. The first time I select Power Off, nothing happens. I have to select Power Off a second time before Fedora starts to shut down. I discovered that if I close all of my open windows, then I only need to select Power Off once.
  1. While updating fedora power tripped
    By balti in forum Using Fedora
    Last Post: 22nd August 2017, 02:04 PM
  2. lost power while updating
    By mscag in forum Using Fedora
    Last Post: 25th October 2010, 12:31 AM
  3. Replies: 4
    Last Post: 24th May 2008, 10:58 PM
  4. Power button ignoring gnome-power-manager on FC8
    By iamasmith in forum Using Fedora
    Last Post: 26th February 2008, 01:29 PM
  5. gnome-power-manager and power button always shutdown
    By exe in forum Hardware & Laptops
    Last Post: 27th January 2007, 07:51 PM
