Results 1 to 8 of 8
    May 2009
    334
    how to mount file system from LIVE DVD
    I screwed up badly and need to simple fix a file in /boot which is on SDA2.
    I have brought up the live DVD for Fedora 24 and got my self into a Terminal.
    I can see /dev/sda2 and it shows up on "fdisk -l"
    It is of type EXT4. When I type
    mkdir /mnt/fu
    mount -t ext4 /dev/sda2 /mnt/fu
    it returns---->
    mount: /dev/sda2 is already mounted or /mnt/fu is busy
    It is definitely not mounted, and fu is not busy.
    I suspect that the live media is not allowing me to do a mount.
    How do I mount it ???
    - this is the only way I can recover the silly error that I made
    HELP!!!!
    Dec 2007
    Australia
    1,675
    Re: how to mount file system from LIVE DVD
    The error message is not definitive. I expect you've checked to see what the system thinks is mounted with the command: mount. I assume you've tried to cd to the partition you tried to mount, but failed. You could try and create another mount point, e.g.: mkdir mounts, and then try and mount /dev/sda2 on /mounts adjusting your command accordingly.
    Are you running f24 or just using the f24 live dvd on another fedora release?
    In any case, I think a specialised rescue cd will do the job you are referring to, something like systemrescuecd. Never failed for me.
    Ventura, CA
    226
    Live Fedora DVD (or live iso on a usb drive) should work for this repair. As nsnbm says, first you should create a mount point as superuser. Then "# mount /dev/sda2 /mounts" should mount your sda2 partition (provided you created the mount-point /mounts). I don't believe you need the -t option followed by ext4.
    Nov 2008
    373
    What you outlined worked for me, with an F25 Live Workstation DVD, as root.
    Oct 2007
    Freedonia
    68
    3,042
    I presume that you've created /mnt/fu during the current live session, because otherwise it won't exist. What do you get if you run this command:
    ls /mnt/fu
    If nothing is mounted there, it's just a normal directory and should be empty. Also you could try this to find out where /dev/sda2 that partition is currently mounted:
    grep /dev/sda2 /etc/mtab
    If there's no output, it isn't mounted.
    Registered Linux user #470359 and permanently recovered BOFH.
    Any advice in this post is worth exactly what you paid for it.
    May 2009
    334
    OK, got it working:
    su
    mkdir /tmp/fu
    mount -rw -t ext3 /dev/sda1 /tmp/fu
    ... the rest depends on what you need to fix - I needed the grub.cfg file copied back ...
    Problem before was I thought it was sda2 not sda1.
    Also /tmp is a writable file system on the live DVD, most are not.
    And yes for the record, I am using Fedora 26 but got there with an upgrade so I used that last DVD I had (24).
    Thanks to all for your help.
    4,728
    As a memory aide:
    When I want to mount a partition on my C drive (the root), what I do is:
    sudo su
    cd /mnt
    mkdir sdc3 # I intend to mount the third partition of /dev/sdc
    mount /dev/sdc3 sdc3
    Occasionally I have to mount several partitions from different drives. Using the system's three letters for the drive and the partition number is a great memory aide.
    When I no longer need the mounted partition I make sure to clean up.
    umount sdc3
    rmdir sdc3
    May 2009
    334
    Nice idea, but I would make the final command
    mount /dev/sdc3 /mnt/sdc3
    Just to remind myself that this is the absolute path!
  1. accessing file system using Live CD
    By saywot in forum Installation, Upgrades and Live Media
    Last Post: 31st March 2012, 03:51 AM
  2. Can I mount a swap file for F13 Live?
    By buddy1138 in forum Installation, Upgrades and Live Media
    Last Post: 13th June 2010, 09:12 PM
  3. Fix for USB: Live Fedora 10 cannot find file system
    By wised in forum Guides & Solutions (Not For Questions)
    Last Post: 30th November 2008, 04:29 PM
  4. How to mount ext3 file system in RAM?
    By viklahan in forum Using Fedora
    Last Post: 23rd October 2008, 11:57 PM
  5. 8e Linux LVM file system - How to mount it?
    By lothario in forum Using Fedora
    Last Post: 14th August 2007, 09:31 PM
