Results 1 to 8 of 8
    Feb 2009
    19
    Problem:- compiler-rt-4.01-4.fc27.i686 has inferior architecture
    I have upgraded to FC 27 from 26. All plain sailing at first. Then just recently received the above message. Any ideas what inferior architecture might actually apply to ?
    doozle
    05.01.2017
    21
    Re: Problem:- compiler-rt-4.01-4.fc27.i686 has inferior architecture
    did you install the 32 bit compiler-rt on a 64 bit machine?
    Feb 2009
    19
    Thanks Kabeero - the post should have been dated 05.12.2017 (!) I have a 64 bit desktop and upgraded to FC27 from 26. I did so using the authorized Fedora website which from memory did not appear to distinguish between 32 or 64 bit machines.
    Doozle
    6,145
    to check which architecture you use if not sure run the following in terminal
    uname -mrs
    also, no need to add a date to posts, the forum will do that automatically along with a time stamp.
    Feb 2009
    19
    uname -mrs
    Thanks for this - pc does not recognise "mrs". What next ?
    Doozle
    Feb 2009
    19
    Since the last post by me I have now been able to find a response, as follows:-
    "linux 4.13.16-302.fc27.x86_64x86_64" Any good ?
    6,145
    Quote Originally Posted by doozle
    yes, it means your installed operating system's architecture is 64-bit
    Feb 2009
    19
    Thanks for this. Does this I should do a fresh install of FC27 ?
  1. lz4-1.7.5-1.fc25.i686 has inferior architecture
    By JoshuaA in forum F26 Development Forum
    Last Post: 18th March 2017, 07:00 PM
  2. What is i686 architecture?
    By atrain_old in forum Using Fedora
    Last Post: 2nd March 2007, 05:16 AM
  3. FC 6 Architecture Selection Problem
    By Peter_APIIT in forum Using Fedora
    Last Post: 9th February 2007, 02:27 AM
