Problems Running VirtualBox on F27
Results 1 to 11 of 11
    Aug 2015
    Idaho
    43
    Attempting to get VirtualBox 5.2.2 r119230 from the website running on Fedora 27.
    I get the following error message when I attempt to start the program:
    Kernel driver not installed (rc=-1908)
    The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
    '/sbin/vboxconfig'
    as root.
    where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
    So I then ran the following:
    [root@lizzie Lizzie]# cd /usr/src/kernels
    [root@lizzie kernels]# ls
    4.13.13-300.fc27.x86_64 4.13.15-300.fc27.x86_64 4.13.16-300.fc27.x86_64
    [root@lizzie kernels]# export KERN_DIR=/usr/src/kernels/4.13.16-300.fc27.x86_64
    [root@lizzie kernels]# /usr/lib/virtualbox/vboxdrv.sh setup
    With the following error message:
    vboxdrv.sh: Stopping VirtualBox services.
    vboxdrv.sh: Building VirtualBox kernel modules.
    vboxdrv.sh: failed: Look at /var/log/vbox-install.log to find out what went wrong.
    With the following message in the log file:
    tail /var/log/vbox-install.log
    /bin/false)
    mkdir -p /lib/modules/4.13.16-300.fc27.x86_64/misc
    make -f ./scripts/Makefile.modinst
    mkdir -p /lib/modules/4.13.16-300.fc27.x86_64/misc ; cp /tmp/vbox.0/vboxpci.ko /lib/modules/4.13.16-300.fc27.x86_64/misc ; true /lib/modules/4.13.16-300.fc27.x86_64/misc/vboxpci.ko ; scripts/sign-file "sha256" "certs/signing_key.pem" certs/signing_key.x509 /lib/modules/4.13.16-300.fc27.x86_64/misc/vboxpci.ko || true && true /lib/modules/4.13.16-300.fc27.x86_64/misc/vboxpci.ko
    At main.c:160:
    - SSL error:02001002:system library:fopen:No such file or directory: crypto/bio/bss_file.c:74
    - SSL error:2006D080:BIO routines:BIO_new_file:no such file: crypto/bio/bss_file.c:81
    sign-file: certs/signing_key.pem: No such file or directory
    /bin/sh ./scripts/depmod.sh /sbin/depmod 4.13.16-300.fc27.x86_64 ""
    /tmp/vbox.0/Makefile.include.header:99: *** The variable KERN_DIR must be a kernel build folder and end with /build without a trailing slash, or KERN_VER must be set. Stop.
    Any suggestions as to what I need to do to resolve this problem?
    Lizzie
    Mar 2004
    In your closet
    16,311
    6 Post(s)
    Re: Problems Running VirtualBox on F27
    Update your system. Reboot. Install kernel-devel-$(uname -r). Rerun /usr/lib/virtualbox/vboxdrv.sh setup
    Take pointers from my install script. https://forums.fedoraforum.org/showt...llation-script
    Aug 2015
    Idaho
    43
    Quote Originally Posted by glennzo
    System has been updated. Kernel-devel has been installed. Still received the same error messages as before when i ran vboxdrv.sh. I looked at you installation script, i just plain do not know enough to really understand it. Any additional assistance would be greatly appreciated.
    Lizzie
    Aug 2017
    US
    69
    I am also having the same problem. Still trying to figure out. . .
    Mar 2004
    In your closet
    16,311
    6 Post(s)
    Have a look at https://ask.fedoraproject.org/en/que...dules-signing/. I think there may be some information that pertains to your issues regarding unsigned kernel modules. This is something I haven't had to deal with but I see this mentioned quite often.
    Aug 2015
    Idaho
    43
    Went to the link you provided and it sent me to an updated version of the article at https://gorka.eguileor.com/vbox-vmwa...x-2016-update/ .
    One of the first steps it has you do is to check vboxdrv with the following command: modprobe -v vboxdrv
    When I did this I got a different error message thatn the one that he appears to be discussing. My error message is as follows:
    sudo modprobe -v vboxdrv
    modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/4.13.16-302.fc27.x86_64.
    Lizzie
    Jan 2010
    8,312
    18 Post(s)
    Just to be sure. uname -r will show a version of the kernel. Check that version against rpm -q kernel-* and make sure it's the same number. I suspect Glenn's right though and it's some sort of signing issue.
    Aug 2017
    US
    69
    Found an easy way out -- Disable the security boot.
    Actually I have been doing this for quite some time. This is a new machine, and I forgot this step. Also I just switched from Ubuntu to Fedora.
    This is a new Ryzen 7 1700 machine with RX 550; the VMs are on an SSD USB stick. Runs super fast!
    Mar 2004
    In your closet
    16,311
    6 Post(s)
    Quote Originally Posted by Lizzie
    Lizzie
    One of the other things the thread talks about is signing the kernel module. That's what Im referring to. This is something I haven't had to deal with, but apparently necessary if you're using secure boot.
    Aug 2015
    Idaho
    43
    Re: Problems Running VirtualBox on F27 (Resolved)
    For whatever reason, VBox is now operational. On a whim this morning, I decided to try and start it. It started right up. Somebondy somewhere did something and the problem has been resolved.
    Lizzie
    1,292
    Lizzie
    I have found this issue many times, and it usually happens when I install VBox, and "then" I decide to upgrade the OS (which changes the kernel version numbers). Somehow the vboxconfig seems to "like" old kernel version numbers in the kernel-devel package. It maybe an interesting idea to always remove all the old kernel-devel packages when doing an upgrade, and then seeing if the vboxconfig exists and runs.
    EDIT: maybe someone at VBox should run a "uname -a" to see what is actually running, before trying to compile a kernel module.
  1. Problems with Fedora 22 KDE Spin running on VirtualBox
    By suk352 in forum Installation, Upgrades and Live Media
    Last Post: 31st July 2015, 04:59 AM
  2. Problems running virtual machines in VirtualBox
    By RX3R0 in forum Using Fedora
    Last Post: 23rd July 2012, 06:37 PM
  3. VirtualBox not running in Fedora 17.
    By Faldegast in forum Using Fedora
    Last Post: 31st May 2012, 11:20 PM
  4. [SOLVED]
    Running F15 beta on VirtualBox 4.0
    By huygens in forum F15 Development
    Last Post: 8th May 2011, 05:36 PM
  5. F12: Can't get VirtualBox running
    By cwebster in forum Using Fedora
    Last Post: 29th December 2009, 08:17 PM
[[template footer(Guest)]]
