Fedora 27 - No System Tray
Results 1 to 8 of 8
    Sep 2017
    Aukland
    26
    Question Fedora 27 - No System Tray
    After a fresh install of Fedora 27 I no longer seem to have access to the system tray. Tried Super+M and that did not work either.
    Sep 2017
    Aukland
    26
    Re: Fedora 27 - No System Tray
    I appear to have the wrong terminology. What is missing is the "Tray Icon Draw"
    Oct 2011
    1,862
    Yeah, they've removed it in Gnome 3.26, use something else if you want the tray
    Aug 2011
    1,943
    Gnome devs removed it because it doesn't fit their vision of the linux desktop (which apparently is a system that looks nice but is dog slow and cannot be used to get any work done).
    They expect you to read the news and install the topicons extension and apparently app devs should use some non-existent replacement apis, just like the mozilla situation.
    5,387
    The system tray is there in a different layout. From the top right corner, click on the screwdriver/wrench icon.
    It will open up the new system tray layout.
    Major setting info is in the left pane, and details are in the right pane.
    For example, look at the background entry. There you see the active and locked screen images.
    I do find there are more/better settings facilities provided.
    Oct 2011
    1,862
    Quote Originally Posted by Dutchy
    Did you tried the extension and it actually worked? Last time I've checked, no extension worked. Extension active, no icons.
    Even if it did work, I am not sure how I feel about Gnome banning this essential feature that is widely spread. They either don't care about any non-gnome software or their aim is too high.
    Jul 2013
    NZ
    434
    topicons extension with f27 works fine for me with things like dropbox and skype.
    5,387
    I use TaskBar. It works GREAT!!!
    Fedora 22 KDE 5 system tray icons missing
    By jmoore58 in forum Using Fedora
    Last Post: 20th November 2015, 04:09 PM
  2. Fedora 16 no system tray found
    By gasdim in forum Using Fedora
    Last Post: 14th February 2012, 10:50 PM
  3. Fedora 12 LXDE X86_64 system tray
    By ancleessen4 in forum Fedora Spins & Remixes
    Last Post: 13th December 2009, 03:15 PM
  4. Fedora 9 KDE taskbar system tray gone
    By jnccneto in forum Using Fedora
    Last Post: 28th June 2008, 05:05 AM
  5. Fedora Core 5 System Tray vanished
    By riksweeney in forum Installation, Upgrades and Live Media
    Last Post: 11th April 2006, 01:14 PM
