Fedora 27 64 bit on macbook 3,1: boot problem after installation
    Jan 2014
    Italy
    6
    [Solved] Fedora 27 64 bit on macbook 3,1: boot problem after installation
    I have a problem with the installation of fedora 27 64 bit on a macbook 3,1 late 2007. I completely removed all mac os x partitions and I installed fedora as UEFI with one ESP partition, two ext4 partitions for operating system and home directory and one partition for swap.
    After the installation, the grub appears and the keyboard does not work. Hence after the grub timeout the operating system gets stuck with blank screen.
    I already tried to change linux kernel option on /etc/default/grub file by removing quiet splash options and by adding nomodeset, but nothing changed,
    Then, If I enter in the mac boot menu by using the option keyboard of the mac, with inserted a live USB of fedora 27 64 bit, I have the following four options:
    Windows
    fedora media
    EFI Boot
    EFI Boot
    If I select fedora media, the grub appears, the keyboard works, I can boot to fedora and it works perfectly.
    I do not know how to avoid to use the fedora USB live and I'm quite sure that is something related to how the grub is launched.
    Do you have any suggestion?
    Thank you
    P.S.
    I have the exact problem also with lubuntu and I cannot solve it.
    Jan 2014
    Italy
    6
    Re: Fedora 27 64 bit on macbook 3,1: boot problem after installation
    I solved in very simple way that I forgot to try. I just reset the NVRAM of the Mac and I reinstalled the operating system.
    Feb 2005
    London, UK
    705
    Hi erotavlas,
    It's worth bearing in mind that your firmware updates are delivered via the software update feature in MacOS, for this reason I always leave a bit of HDD space available to dual boot MacOS.
    Regards,
    Haydn.
    Jan 2014
    Italy
    6
    Quote Originally Posted by HaydnH
    Hi erotavlas,
    Regards,
    Haydn.
    thank you for your information. I have serious doubts about the firmware update since the macbook 3,1 does not receive any update since 25 July 2011 i.e. 10.6.8 version.
    Can't boot Fedora 13 on macbook pro 5,5
    By githros in forum Mac Chat
    Last Post: 27th May 2010, 07:31 PM
  2. Fedora won't boot on my Macbook Pro 5,3
    By djhyland in forum Mac Chat
    Last Post: 2nd April 2010, 09:41 PM
  3. Live CD failed to run on MacBook, now MacBook won't boot
    By noname in forum Installation, Upgrades and Live Media
    Last Post: 4th November 2009, 04:19 PM
  4. Fedora KDE 7 Won't Boot On Macbook
    By IamNoBody in forum Installation, Upgrades and Live Media
    Last Post: 15th August 2007, 10:31 AM
  5. installation problem on new macbook pro
    By cladsa in forum Installation, Upgrades and Live Media
    Last Post: 13th July 2007, 11:46 AM
