MINIX NEO Z83-4 Pro Mini-PC:
[root@mallorca2 bobx]# inxi -Fxmz
System: Host: mallorca2 Kernel: 4.15.4-300.fc27.x86_64 x86_64 bits: 64 gcc: 7.3.1
Desktop: LXDE (Openbox 3.6.1) Distro: Fedora release 27 (Twenty Seven)
Machine: Device: desktop System: MINIX product: Z83-4 Pro v: V1.1 serial: N/A
Mobo: MINIX model: NEO Z83-4 v: V1.1 serial: N/A
UEFI: American Megatrends v: PHT0A110 date: 04/10/2017
CPU: Quad core Intel Atom x5-Z8350 (-MCP-) arch: Airmont rev.4 cache: 1024 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11520
clock speeds: max: 1920 MHz 1: 962 MHz 2: 1020 MHz 3: 574 MHz 4: 554 MHz
Memory: Array-1 capacity: 8 GB devices: 2 EC: Multi-bit ECC
Device-1: A1_DIMM0 size: 4 GB speed: 1600 MT/s type: DDR3 part: N/A
Device-2: A1_DIMM1 size: No Module Installed type: N/A
Graphics: Card: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers
bus-ID: 00:02.0
Display Server: X.org 1.19.6 drivers: modesetting (unloaded: fbdev,vesa)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (Cherrytrail) version: 4.5 Mesa 17.3.5 Direct Render: Yes
Audio: Card-1 Intel HDMI/DP LPE Audio driver: HdmiLpeAudio Sound: ALSA v: k4.15.4-300.fc27.x86_64
Card-2 chtrt5645 driver: chtrt5645
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 2000.4GB (50.2% used)
ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
ID-2: USB /dev/sda model: External size: 2000.4GB temp: 0C
Partition: ID-1: / size: 21G used: 4.5G (23%) fs: ext4 dev: /dev/mmcblk0p3
ID-2: swap-1 size: 6.29GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p2
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 54.9C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 190 Uptime: 1:09 Memory: 471.8/3744.7MB Init: systemd runlevel: 5 Gcc sys: N/A
Client: Shell (bash 4.4.191) inxi: 2.3.56
Rikomagic RKM36S Mini-PC:
[root@mallorca1 ~]# inxi -Fxmz
System: Host: mallorca1 Kernel: 4.15.3-300.fc27.x86_64 x86_64 bits: 64 gcc: 7.3.1 Console: tty 1
Machine: Device: desktop System: RKM product: MK36S v: 0.38 serial: N/A
Mobo: RKM model: Cherry Trail CR serial: N/A UEFI: American Megatrends v: 5.011 date: 12/13/2015
CPU: Quad core Intel Atom x5-Z8300 (-MCP-) arch: Airmont rev.3 cache: 1024 KB
clock speeds: max: 1840 MHz 1: 479 MHz 2: 479 MHz 3: 664 MHz 4: 1166 MHz
Device-1: A1_DIMM0 size: 2 GB speed: N/A type: DDR3 part: N/A
bus-ID: 00:02.0
tty size: 126x31 Advanced Data: N/A for root out of X
Audio: Card-1 Intel HDMI/DP LPE Audio driver: HdmiLpeAudio Sound: ALSA v: k4.15.3-300.fc27.x86_64
Card-2 USB Audio Device driver: USB-Audio
Card-3 bytcht-nocodec driver: bytcht-nocodec
Card-4 C-Media driver: USB Audio usb-ID: 001-006
Network: Card: Intel Wireless 3160 driver: iwlwifi bus-ID: 01:00.0
IF: wlp1s0 state: up mac: <filter>
Drives: HDD Total Size: NA (-)
Partition: ID-1: / size: 24G used: 5.8G (27%) fs: ext4 dev: /dev/mmcblk0p3
ID-2: swap-1 size: 3.67GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p2
Sensors: System Temperatures: cpu: 46.0C mobo: N/A
Info: Processes: 169 Uptime: 54 min Memory: 1437.7/1922.1MB Init: systemd runlevel: 3 Gcc sys: N/A
