disable cinnamon desktop sound effects
    Sep 2004
    13
    I am trying to disable sounds in desktop effects on Fedora 27 Cinnamon. Like window open/close, login etc. I cannot find it in any settings/control center. Google search for "disabling cinnamon sound effects" returns hints to "System Seetings -> Sound", apparently in Mint Linux, as there is no "Sound" in F27 Cinnamon System Settings.
    Worse enough, disabling Window effects in Effects does not silence them.
    any help?
    Havant
    177
    Re: disable cinnamon desktop sound effects
    Look harder!
Name:	Screenshot from 2017-11-19 17-19-06.jpg
Name:	Screenshot from 2017-11-19 17-20-50.jpg
    Sep 2004
    13
    sorry, i have not noticed the scrollbar
    disable desktop effects in gnome in console
    By scott36 in forum Using Fedora
    Last Post: 7th July 2010, 11:08 AM
  2. KDE desktop effects how to disable
    By vsugadhan in forum Using Fedora
    Last Post: 19th April 2009, 08:38 PM
  3. I want to disable Desktop Effects
    By majikthise in forum Alpha - Beta (Fedora 9 Only)
    Last Post: 26th April 2008, 04:08 PM
  4. Disable desktop effects in F8
    By jbromley in forum Using Fedora
    Last Post: 11th December 2007, 03:52 AM
  5. Selectively disable desktop effects?
    By leadgolem in forum Using Fedora
    Last Post: 19th July 2007, 04:15 AM
