    Feb 2016
    Germany
    17
    qesteidutil (need help with build)
    some days ago was an critical update to qesteidutil (estonian ID-card software). At the moment the updating version is not in F27 repositories. But there is a github repo with the actual version ( https://github.com/open-eid/qesteidutil )
    Build instructions are only for ubuntu/debian OSX and windows.
    How can I build this in fedora?
    BTW: If I try the ubuntu intructions i get stuck at "cmake .." with the folliwing error
    -- Could NOT find PCSC-Lite (missing: PCSCLITE_LIBRARY PCSCLITE_INCLUDE_DIR)
    CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
    Thanks in advance!
    Mar 2011
    5,110
    Re: qesteidutil (need help with build)
    I suggest starting with
    dnf install cmake openssl-devel qt5-qttools-devel pcsc-lite-devel
    This will get all the build requirements listed installed.
    Fedora 27 x86_64 XFCE - Sager | Intel Core i7 - 4810 MQ | NVIDIA GeForce GTX 860M | 16 GB RAM | 480 GB ADATA SSD |
    Fedora 27 x86_64 XFCE - Dell Precision M4800 | Intel Core i7 - 4900 MQ | NVIDIA Quadro K1100M | 16 GB RAM | 750 GB 7200 RPM HDD |
    The Linux Documentation Project | Fedora Documentation
    Mar 2011
    5,110
    I think you will probably encounter the same issue that shows up here - https://aur.archlinux.org/packages/qesteidutil/
    Those compilation errors are due to glibc changes. Those would need to be patched for the compilation to work (which is beyond me). Sorry!
    Feb 2016
    Germany
    17
    pcsc-lite-devel was missing.
    But as you notices I got another issue.
    Okay, I will run this software on an ubuntu VM.
    But THANK YOU VERY MUCH!
  1. [SOLVED] Build error with Fedora 16 - thoggen - dependency build error - hal?
    By jonathonp in forum Using Fedora
    Last Post: 17th November 2011, 08:59 AM
  2. Trying to build pcsx2 - errors during build
    By Witgetsteinsbee in forum Using Fedora
    Last Post: 29th March 2011, 11:30 PM
  3. rpm build help
    By olima in forum Using Fedora
    Last Post: 24th April 2009, 07:08 PM
  4. Cannot install Module::Build without Module::Build
    By hackman989 in forum Using Fedora
    Last Post: 14th July 2006, 02:58 PM
  5. rpm build
    By vijay in forum Using Fedora
    Last Post: 24th January 2005, 02:03 PM
