Plugable bluetooth usb not operational in fedora 26
    May 2011
    33
    Dear Fedora experts
    Recently a Plugable Bluetooth USB adapter has bought. Should work with windows and linux.No problems with sending files between pc with windows 10 and Samsung J3.phone. Fedora 26 to recognizes the bluetooth item and connect to the phone. The phone itself indeed shows the connection to the pc. However if a file is sent from pc to phone an error message occurs " The connection tot Samsung J3" has failed. Reversely from phone tot pc the same occurs.
    Looking at my network configuration the wifi connection is visible and operational. The phone Samsung J3 is visible under the bluetooth header. Clicking the bluetooth connecion an error occurs " Connection don't have the setting gsm" . Clicking this error then additional information is given " Failed to get secrets".
    " Secrets" mean to me password, pincode simcode etc. I have no idea why it is needed.
    In addition the system continues making connection with the phone but replies anytime :" Connection failed" or " Connection time out".
    Is there anybody who can help and suggest me what to do ?
    Thanks in advance
    rvenk
    May 2011
    33
    Re: Plugable bluetooth usb not operational in fedora 26
    The problem has been solved. The settings using by fedora or by windows during bluetooth operation are different. Switch off the windows connection makes the fedora connection working. The Plugable Bluetooth USB adapter operates indeed both for linux as windows.
    rvenk
  1. FC23 - plugable USB/ethernet
    By agileape in forum EOL (End Of Life) Versions
    Last Post: 30th June 2017, 04:39 PM
  2. Which repos are supposed to be operational right now?
    By Boricua in forum F24 Development Forum
    Last Post: 11th June 2016, 03:33 PM
  3. Perhaps this is an operational risk
    By quasar66 in forum Security and Privacy
    Last Post: 17th September 2010, 09:14 PM
  4. Fedora 10 Network Operational Again
    By LinuxTom in forum Using Fedora
    Last Post: 12th December 2008, 08:26 PM
  5. CD Burning Not Operational
    By j_baer in forum Fedora Core 5 - Dev
    Last Post: 20th January 2006, 08:10 PM
