[SOLVED] External IP keep changing. How do I keep it?
Results 1 to 7 of 7
    Oct 2017
    Canada
    11
    My external IP keep changing all the time and it can get frustrating because sometimes I will be able to SSH to my home PC but then, suddenly, not anymore because my external IP changed. How do I stop my external IP from changing? Do I have to call my ISP? Or is there anyway to keep it?
    Apr 2009
    central NY, USA
    1,119
    Re: External IP keep changing. How do I keep it?
    It will cost you extra to get a 'static IP' from your ISP. You may want to investigate a dynamic DNS solution. We use DYNDNS.com but I am sure there are others. Ours costs as well, but works great.
    Change - the only constant.
    Oct 2011
    1,836
    I've used no-ip in the past, until they've changed to make user renew free domain every month. I am using Dynu now. I like the short suffix and the options it provides.
    You will also also need a client that reports IP address to Dynamic DNS service from time to time. Some routers supports the most used services out of the box, for Dynu I had to install `ddclient` on the server to do that.
    Oct 2011
    1,836
    Also, I think switching to IPv6 would provide a free static IPv6 address if your Internet service provider supports it. Ask your service provider for more details.
    Oct 2017
    Canada
    11
    I called my ISP and they should give me a static IP in a few days.
    May 2011
    228
    Was it cheap? My ISP charges an arm and a leg to have a static IP. I envy you.
    Feb 2009
    Florida
    638
    You could Google "Dynamic Domain Name Service" to find service providers and plans to your liking. Some services are "Free" and others require a fee. The service itself provides an internet domain name for your IP address that will track changes as they occur.
    Laptop: Toshiba / Intel B960 2.20Ghz x2/ 4GB/ 320GB SataII/ Intel HD/ fc28.x86_64
    Tower: GigaByte (970A) / AMD FX 8320 3.5Ghz x8/ 16GB/ 9TB Sata III/ AMD 6770HD/ fc28.x86_64
    Bookshelf: Shuttle DS61 (H61)/ i3-3225 3.3Ghz x2/ 16GB/ 320GB Sata II/ Intel HD 4000/ fc27.x86_64
  1. External USB drive via external laptop SATA enclosure on FC7 box
    By Michael_13 in forum Hardware & Laptops
    Last Post: 22nd June 2008, 02:46 PM
  2. Changing user and group of files on external USB Hard Drive
    By bullet45 in forum Hardware & Laptops
    Last Post: 23rd July 2006, 04:19 PM
  3. Changing HDD with OS
    By narasim_7 in forum Fedora Focus
    Last Post: 11th March 2006, 10:27 AM
  4. changing to 100 Hz
    By TranceDude in forum Using Fedora
    Last Post: 27th November 2005, 09:49 AM
  5. Changing Name
    By Shof515 in forum Servers & Networking
    Last Post: 24th November 2005, 04:11 AM
