    Oct 2017
    US
    Battery Threshold
    Hi, im Running Fedor 26 on my asus Zenbook3 UX390
    when i was running windows i noticed that the battery did not charge over 98%
    so it would trickle charge between 93-98.
    I have installed TLP and powerto.
    I tried with TLP first and noticed most of everything was for thinkpads
    and i could not get close with powertop
    can anyone help me set a battery threshold.
    Thank you
    Oct 2007
    Freedonia
    68
    3,036
    Re: Battery Threshold
    I have an old laptop that never shows the battery as 100%, although it did when I bought it. A friend of mine who knows hardware tells me that sometimes components change their values slightly, and that this is probably all that's happened. As long as it holds enough charge to work and consistently goes up to almost 100%, don't worry about the reading.
    Registered Linux user #470359 and permanently recovered BOFH.
    Any advice in this post is worth exactly what you paid for it.
    Feb 2005
    London, UK
    565
    Have a look at the files under /sys/class/power_supply/BAT0/, you'll find max charge, current charge etc in there.
  1. xfce battery panel displaying wrong ETA on battery life
    By SpaceKookie in forum Using Fedora
    Last Post: 21st September 2015, 04:01 AM
  2. CPU above threshold frequency....
    By praddie in forum Using Fedora
    Last Post: 1st August 2006, 12:52 PM
  3. CPU Threshold too high?
    By matrixtna in forum Using Fedora
    Last Post: 21st March 2005, 01:05 AM
  4. set fan activation threshold...
    By spidernik84 in forum Hardware & Laptops
    Last Post: 12th March 2005, 12:12 AM
