    Jan 2010
    The Netherlands
    46
    256
    ffmpeg, how to record a webcast sound
    I was using a following command to record a webcast (video+audio):
    ffmpeg -f alsa -ac 2 -i pulse -f x11grab -framerate 25 -video_size 1920x1080 -i :1 -acodec pcm_s16le -vcodec libx264 -crf 0 -preset ultrafast ScreenCast.mkv
    To my great disappointment, it also recorded all sounds picked up by the microphone, which totally ruined the webcast recording.
    Is it possible to instruct ffmpeg to record the audio stream but not the microphone?
    Fedora25.GNOME@Dell_Latitude_E7440
    Fedora24.MATE@HP_Compaq_DC7100
    Jan 2010
    The Netherlands
    46
    256
    Re: ffmpeg, how to record a webcast sound
    The solution = pavucontrol can be used to select the recording source; in my case it is 'Monitor of Built-in Audio Analog Stereo'
    By the way, the menu appears only when the recording is started, otherwise nothing is there to select. This is my screenshot...
  1. i cant record my sound
    By coreyscx in forum Using Fedora
    Last Post: 8th September 2011, 06:26 AM
  2. How to record sound in F12?
    By Sordep in forum Using Fedora
    Last Post: 5th January 2010, 10:20 PM
  3. No sound unless I record with mic?
    By amrclutch1 in forum Using Fedora
    Last Post: 14th March 2008, 08:16 PM
  4. live webcast recording
    By LinuxHippy in forum Using Fedora
    Last Post: 2nd June 2006, 07:17 PM
  5. Can't record sound
    By erlkoenig in forum Hardware & Laptops
    Last Post: 26th February 2005, 07:48 PM
