Results 1 to 11 of 11
    Sep 2017
    morroco
    6
    Exclamation Problem bluetooth fedora 26
    Hello.
    I have a problem in bluetooth, when i choose ON system won't found any devices
    (photo) https://forums.fedoraforum.org/attac...1&d=1504782537
    $ lsusb
    Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 Device 005: ID 0bda:58c2 Realtek Semiconductor Corp.
    Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
    Bus 001 Device 003: ID 0a5c:21d7 Broadcom Corp. BCM43142 Bluetooth 4.0
    Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 002: ID 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    $ systemctl status bluetooth
    ● bluetooth.service - Bluetooth service
    Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor pr
    Active: active (running) since Thu 2017-09-07 11:53:50 WEST; 13min ago
    Docs: man:bluetoothd(8)
    Main PID: 632 (bluetoothd)
    Status: "Running"
    Tasks: 1 (limit: 4915)
    CGroup: /system.slice/bluetooth.service
    └─632 /usr/libexec/bluetooth/bluetoothd
    Sep 07 11:53:48 localhost.localdomain bluetoothd[632]: Bluetooth daemon 5.46
    Sep 07 11:53:50 localhost.localdomain systemd[1]: Started Bluetooth service.
    Sep 07 11:53:50 localhost.localdomain bluetoothd[632]: Starting SDP server
    Sep 07 11:53:50 localhost.localdomain bluetoothd[632]: Bluetooth management inte
    Sep 07 11:53:50 localhost.localdomain bluetoothd[632]: Failed to set mode: Block
    Sep 07 11:54:21 localhost.localdomain bluetoothd[632]: Failed to set mode: Block
    Sep 07 11:54:34 localhost.localdomain bluetoothd[632]: Endpoint registered: send
    Sep 07 11:54:39 localhost.localdomain bluetoothd[632]: Failed to set mode: Block
    Sep 07 11:57:04 localhost.localdomain bluetoothd[632]: Failed to set mode: Block
    lines 1-20/20 (END)
    rfkill list
    0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
    1: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Screenshot from 2017-09-07 12-06-33.png
    Sep 2017
    morroco
    6
    Re: Problem bluetooth fedora 26
    any help pls
    5,240
    welcome to the forum, please don't bump your thread within 48 hours of posting it. if someone knows the answer they will get back to you. the forum is a fedora user community. we are not officially connected to redhat or paid to support fedora.
    Feb 2005
    London, UK
    526
    Have you installed the drivers using the akmod-wl package from the rpmfusion repos?
    Sep 2017
    morroco
    6
    Quote Originally Posted by HaydnH
    no, I don't know how
    ---------- Post added at 09:27 PM ---------- Previous post was at 09:24 PM ----------
    Quote Originally Posted by jdotnet
    I try this .
    $ sudo dnf install akmod-wl
    [sudo] password for dotnet:
    Last metadata expiration check: 2:53:49 ago on Thu 07 Sep 2017 07:32:10 PM WEST.
    Package akmod-wl-6.30.223.271-13.fc26.x86_64 is already installed, skipping.
    Dependencies resolved.
    Nothing to do.
    Complete!
    Sep 2017
    morroco
    6
    Any help pls
    Feb 2005
    London, UK
    526
    Run "akmods --force" once you have it installed.
    Sep 2017
    morroco
    6
    $ sudo akmods --force
    Checking kmods exist for 4.12.9-300.fc26.x86_64 [ OK ]
    what I do?
    Sep 2017
    morroco
    6
    Any help pls
    May 2009
    4
    I am running Fedora 26 on Lenovo G505s laptop with AMD A8 processor.
    Fedora does not recognise the Bluetooth hardware.
    Settings section of Fedora 26 shows no Bluetooth and asks me to connect a dongle to get bluetooth.
    Ask A Human project
    www.iqmind.org
    May 2009
    4
    Thumbs up Re: Problem bluetooth fedora 26
    any help pls
    Hey dotnet,
    CHECK OUT this thread:
    https://forums.fedoraforum.org/showthread.php?t=216580
    The Two Commands helped me Turn On my Bluetooth on my Lenovo G505s laptop running AMD processor.
    sudo chkconfig bluetooth on
    sudo service bluetooth start
    http://lists.usefulinc.com/pipermail...ly/000938.html
    MANY THANKS to CokeDude user from that thread.
    Bluetooth option inside Settings now lists nearby Bluetooth devices and I was able to connect to bluetooth speaker in just one click.
    Yay.
    Ujjwal Dey
    www.iqmind.org
    Ask A Human Project
    Ask A Human project
    www.iqmind.org
  1. problem with bluetooth in fedora 15
    By seyd-ali in forum Hardware & Laptops
    Last Post: 11th September 2011, 12:11 PM
  2. Bluetooth audio problem in Fedora 11
    By hilbert24 in forum Using Fedora
    Last Post: 29th September 2009, 08:40 PM
  3. Yet another Fedora 10 / Bluetooth / headset problem...
    By tiger762 in forum Hardware & Laptops
    Last Post: 19th January 2009, 11:13 PM
  4. [SOLVED] Problem With Bluetooth in Fedora 10
    By Sigmund in forum Servers & Networking
    Last Post: 11th January 2009, 10:23 PM
  5. Problem With Bluetooth in Fedora 10
    By jeffy5 in forum Using Fedora
    Last Post: 9th January 2009, 11:54 AM
