I need help softimage 3d please !
Results 1 to 11 of 11
    Sep 2017
    Canada
    5
    I need help, I need to work Softimage 3d 4.0 2002, was launched for Linux Red Hat 6.2 on 2002 (without being version Enterprise) I try to run the Setup installer file, but not it just pops up, some help of how to proceed? What do I do? The installation simply does not appear, even clicking to run, what do I do? Any help? Fedora 26? please !.
    Do you need to host my disk file for analysis?
    6,508
    Re: I need help softimage 3d please !
    try running it with CentOS 6.9 either in virtual machine or as a bare metal install. that is your best bet at getting the correct supporting libraries the program requires
    https://wiki.centos.org/Download
    Sep 2017
    Canada
    5
    It requires only the Xfree 4.01
    6,508
    well that could be an issue since Fedora has used Xorg instead of xfree for as long as I can remember. Admittedly I've only really been using Fedora long term since version 20 but in Fedora terms that's a long time.
    CentOS 6 appears to use Xorg too
    Sep 2017
    Canada
    5
    But I think it should work, I'll try it tomorrow.
    Sep 2017
    Canada
    5
    It did not work, installed CentOS 6.9 I upgraded with Yum Update command, tried to run the setup but pops up the following error: There are no packages to run executable files. have anywhere solution ?
    6,508
    are there any installation instructions with the program? did it come in a compressed tar.gz archive you need to unpack or are you actually trying to run a file ending in exe on linux rather than a linux program?
    It would be useful to know exactly what you are doing with this mystery executable to try and install it. please give step by step details.
    Sep 2017
    Canada
    5
    It is the CD Softimage 3d 4.0 executable made for Linux launched for Red Hat 6.2 (note: It is not for Enterprise version), it comes Linux executable file accompanied by tar.gz: Render, export, import only
    6,508
    again, please give step by step details of what you are doing.
    our trusty crystal ball has gone for an annual overhaul I'm afraid, so without this very basic information it will be extremely difficult/impossible to help.
    Jul 2004
    Colton, NY; Junction of Heaven & Earth (also Routes 56 & 68).
    73
    23,592
    Here's your problem:
    Softimage|3D is a discontinued high-end 3D graphics application developed by Softimage, Co., which was used predominantly in the film, broadcasting, gaming, and advertising industries for the production of 3D animation. It was superseded by Softimage XSI in 2000.
    In other words, it's over 15 years dead. Use something else. Also this: https://www.autodesk.com/products/softimage/overview which indicates that you would have had to purchase it, while it was alive.
    Registered Linux User #362651
    GallComp's Avatar
    GallComp is offline Nuke 'em Alfred! Administrator - Starring in Bill & Steve's Bogus Journey
    Mar 2004
    Fontana, CA
    42
    2,503
    Quote Originally Posted by bob
    Even the XSI version has been discontinued, the last version was released in 2014, named Softimage 2015. The support ended in may 2016.
    For the OP, you should try Blender, it is free, powerful, and in active development.
    "Since when has the world of computer software design been about what people want? This is a simple question of evolution. The day is quickly coming when every knee will bow down to a silicon fist, and you will all beg your binary gods for mercy. "
    BILL GATES...
