Results 1 to 11 of 11
    Aug 2017
    New Zealand
    23
    Need help with stuffed partitions
    Good evening/day/morning,
    I was planning to make it a dual boot laptop with Windows 10/Linux and was working to join a main Windows partition with another one infront of it, when this failed. After PC was restarted and the actual process begun, It was stuck on 0% for about 30m and eventually restarted the machine one more time.
    No windows 10 start up recovery tools could fix this mess. This was a 3rd party tool that worked for me beforehand.
    What are my options? I have had some data that I sort of need, but can leave without. I booted via Live CD and this is what fdisk produced. Is it possible to mount the partitions in this situation?
    [liveuser@localhost-live ~]$ fdisk -l
    fdisk: cannot open /dev/sda: Permission denied
    fdisk: cannot open /dev/sdb: Permission denied
    fdisk: cannot open /dev/loop0: Permission denied
    fdisk: cannot open /dev/loop1: Permission denied
    fdisk: cannot open /dev/loop2: Permission denied
    fdisk: cannot open /dev/mapper/live-rw: Permission denied
    fdisk: cannot open /dev/mapper/live-base: Permission denied
    I will appreciate any feedback.
    Aug 2005
    697
    Re: Need help with stuffed partitions
    fdisk needs to be run as root. IIRC there is no password set for root on the Live DVD so you just do:
    $ su -
    # fdisk -l
    Then you can mount the partitions on the real disks that fdisk lists and see what is on them, e.g.:
    # mkdir /mnt/sda1
    # mount /dev/sda1 /mnt/sda1
    # ls /mnt/sda1
    # mkdir /mnt/sdb1
    # mount /dev/sdb1 /mnt/sdb1
    # ls /mnt/sdb1
    # umount /mnt/sdb1
    # umount /mnt/sda1
    # exit
    Aug 2017
    New Zealand
    23
    Quote Originally Posted by kldixon
    $ su -
    # fdisk -l
    # mkdir /mnt/sda1
    # ls /mnt/sda1
    # mkdir /mnt/sdb1
    # ls /mnt/sdb1
    # umount /mnt/sdb1
    # umount /mnt/sda1
    # exit
    Thanks, will try today when at home.
    Aug 2017
    New Zealand
    23
    $ su -
    # fdisk -l
    # mkdir /mnt/sda1
    # ls /mnt/sda1
    # mkdir /mnt/sdb1
    # ls /mnt/sdb1
    # umount /mnt/sdb1
    # umount /mnt/sda1
    # exit
    Tried what was suggested. But got the message:
    Mount: wrong fs type, bad option, bad superblock on /dev/sda3, missing codepage or helper program, or other error.
    I am assuming that Live CD needs NTFS drivers installed as this is a Windows NTFS partition?
    ramzes.
    5,270
    not necessarily, sda3 could be an OEM or Windows Recovery Partition. Which Live media are you using? If workstation there will be a utility called Disks. Run that and it will show a lot more information about the existing partitions on your SSD. Other images should have GParted which does the same thing but allows you to also edit the partition layout.
    Aug 2005
    697
    Also, could you list the output of fdisk -l, run as root, here, in code tags
    https://forums.fedoraforum.org/misc.php?do=bbcode#code
    Just noticed your other thread.
    Aug 2017
    New Zealand
    23
    Sorry for the image quality, for some silly reason the screenshot I've saved on the USB drive on Linux live machine would is not viewable on PC and in Google Drive.
    https://drive.google.com/open?id=0B_...VWX09GME1taDg0
    Aug 2017
    New Zealand
    23
    Basically where there is free space on the photo is my Primary Windows partition. I run a job of joining with preceding small partition of 500mb, that was unallocated space.
    I must say I attempted to use TestDisk to fix it.
    5,270
    actually it looks like rather than merge any partitions it's just deleted your windows operating system partition, as there is no way you'd fit windows into a 1 GiB partition.
    If it were me, I'd start again from scratch with an empty drive and reinstall windows if you still want it first.
    Aug 2017
    New Zealand
    23
    Thank you for your reply. I will just start with a fresh install. As there is no data I horribly need.
    Aug 2017
    New Zealand
    23
    Figured out what was the problem.
    Disk merge damaged system W10 partition.
    Further experiments with testdisk converted my disk type to MBR. I further struggled to change it back to GPT and keep the data and W10 recovery partition.
    So I ended up using Diskpart off W10 bootable USB, and removed all partitions and cleared the disk.
    Changed disk type to GPT, formatted, partitioned and installed Linux
  1. [SOLVED] Stuffed up grub 2
    By KiwiLegion in forum Using Fedora
    Last Post: 16th April 2013, 10:15 AM
  2. KDE desktop stuffed up
    By tameboy in forum Using Fedora
    Last Post: 10th August 2008, 12:20 PM
  3. Stuffed GUI
    By xion101 in forum Using Fedora
    Last Post: 10th December 2005, 04:57 PM
  4. stuffed my key mappings!
    By tfindlay in forum Using Fedora
    Last Post: 13th September 2005, 02:31 PM
