    Jul 2017
    Ukraine
    Problem with cooler
    Hello!
    Recently I have installed new Fedora 26 on my Laptop DELL Inspiron 5558
    Everything is working fine. But when i use wine and play hearthtone or some other games and when i close game window my cooler works and works. When he blows cold he turns on. Turns for some reason do not automatically fall off after cooling. It helps only reboot the laptop and then it works quietly. sorry for my eng
    Pls help
    May 2017
    www
    135
    Re: Problem with cooler
    If you play a game for a long time the laptop could be overheated so the fan would stay on until it's below a certain temperature. You could adjust the speed in your BIOS or install third-party software if you really want to change it..
    You can also buy a cooling pad which should should help, such as this
    https://www.youtube.com/watch?v=anUyV4rn0SI
  1. cpu cooler question
    By lsatenstein in forum Hardware & Laptops
    Last Post: 14th March 2017, 04:09 PM
  2. [SOLVED] CPU Cooler Hyperbolix vs actual performance?
    By Dan in forum Hardware & Laptops
    Last Post: 20th January 2013, 06:48 PM
  3. which one runs cooler (32 or 64 bit)?
    By PiElle in forum Using Fedora
    Last Post: 19th April 2012, 10:48 AM
  4. Replies: 4
    Last Post: 16th May 2009, 11:30 AM
  5. notebook cooler helps!
    By saabnuts in forum Hardware & Laptops
    Last Post: 7th December 2005, 01:52 AM
