I have just upgraded to F26, which upgraded PostgreSQL to 9.6 from 9.5
I use PgAdminIII frequently, but now it warns it only covers versions up to 9.5.
PgAdmin4 is compatible with 9.6, but installation fails as follows:
[root@womble Flask-Babel-0.11.2]# dnf search pgadmin4
Last metadata expiration check: 2:54:41 ago on Tue 18 Jul 2017 14:32:29 AEST.
============================================================== Summary & Name Matched: pgadmin4 ==============================================================
pgadmin4-v1-web.noarch : pgAdmin4 web package
pgadmin4-v1-docs.noarch : pgAdmin4 documentation
pgadmin4-v1-debuginfo.x86_64 : Debug information for package pgadmin4-v1
pgadmin4-python3-pyrsistent-debuginfo.x86_64 : Debug information for package pgadmin4-python3-pyrsistent
=================================================================== Name Matched: pgadmin4 ===================================================================
pgadmin4-v1.x86_64 : Management tool for PostgreSQL
pgadmin4-python3-flask.noarch : A micro-framework for Python based on Werkzeug, Jinja 2 and good intentions
pgadmin4-python3-wtforms.noarch : Forms validation and rendering library for python
pgadmin4-python3-fixtures.noarch : Fixtures, reusable state for writing clean tests and more
pgadmin4-python3-html5lib.noarch : A python based HTML parser/tokenizer
pgadmin4-python3-flask-wtf.noarch : Simple integration of Flask and WTForms
pgadmin4-python3-mimeparse.noarch : Python module for parsing mime-type names
pgadmin4-python3-Flask-Mail.noarch : A Flask extension for sending email messages
pgadmin4-python3-pyrsistent.x86_64 : Persistent/Functional/Immutable data structures
pgadmin4-python3-flask-babel.noarch : Adds i18n/l10n support to Flask applications
pgadmin4-python3-flask-login.noarch : User session management for Flask
pgadmin4-python3-flask-htmlmin.noarch : Flask html response minifier
pgadmin4-python3-flask-gravatar.noarch : Small extension for Flask to make usage of Gravatar service easy
pgadmin4-python3-flask-security.noarch : Simple security for Flask apps
pgadmin4-python3-flask-principal.noarch : Identity management for Flask applications
[root@womble Flask-Babel-0.11.2]# dnf install pgadmin4*
Last metadata expiration check: 2:55:21 ago on Tue 18 Jul 2017 14:32:29 AEST.
Package pgadmin4-python3-flask-1:0.11.1-7.f26.noarch is already installed, skipping.
Error:
Problem 1: conflicting requests
- nothing provides python3-flask-babel >= 0.11.1 needed by pgadmin4-v1-web-1.6-1.f26.noarch
- nothing provides python3-flask-babel >= 0.11.1 needed by pgadmin4-v1-web-1.6-2.f26.noarch
Problem 2: conflicting requests
- package pgadmin4-v1-1.6-1.f26.x86_64 requires pgadmin4-v1-web, but none of the providers can be installed
- package pgadmin4-v1-1.6-2.f26.x86_64 requires pgadmin4-v1-web, but none of the providers can be installed
[root@womble data]# dnf install pgadmin4-python3-flask-babel
Last metadata expiration check: 0:12:53 ago on Wed 19 Jul 2017 12:16:38 AEST.
Dependencies resolved.
Package Arch Version Repository Size
Installing:
pgadmin4-python3-flask-babel noarch 0.11.1-3.f26 pgdg96 53 k
Transaction Summary
Install 1 Package
Total download size: 53 k
Installed size: 115 k
Is this ok [y/N]: y
Downloading Packages:
pgadmin4-python3-flask-babel-0.11.1-3.f26.noarch.rpm 19 kB/s | 53 kB 00:02
Total 19 kB/s | 53 kB 00:02
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : pgadmin4-python3-flask-babel-0.11.1-3.f26.noarch 1/1
Verifying : pgadmin4-python3-flask-babel-0.11.1-3.f26.noarch 1/1
Installed:
pgadmin4-python3-flask-babel.noarch 0.11.1-3.f26
Complete!
[root@womble data]# dnf install pgadmin4*
Last metadata expiration check: 0:13:53 ago on Wed 19 Jul 2017 12:16:38 AEST.
Package pgadmin4-python3-flask-babel-0.11.1-3.f26.noarch is already installed, skipping.
Error:
I had hoped installing pgadmin4-python3-flask-1:0.11.1-7.f26.noarch would have satisfied the requirement for python3-flask >= 1.0.11, but no such luck.
Any suggestions would be appreciated.
Kind regards,
Doug
